Home > Puma (Tdci) > 2.2 Turbo/Intercooler pipe recall. *** WARNING *** |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Poor you, I hope its nothing serious and they sort it quickly
7th Jul 2013 7:34pm |
Had the same when my truck was also relatively new. Went into limp mode several times with engine mgmt light coming on like yours, but nothing wrong with the turbo. Limp mode means no turbo of course. It actually was all down to a faulty EGR valve, which once replaced under warranty, never went into limp mode again.
Hope it is as simple as that in your case too. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
7th Jul 2013 7:42pm |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 |
I hope so too. They've cancelled on me now and told me it will be 8am tomorrow morning.
Another day late to work because of Land Rover. |
7th Jul 2013 7:43pm |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 724 |
Hi, we had the same last weekend, puddle of water too... Turned out the turbo hose had come off, and the clip was still there! Happy days!! Hope yours is as simple, sounds just the same symptoms
Alex |
7th Jul 2013 9:13pm |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
Sounds like your intercooler pipe has come off.
Land Rover are here now. Apparently the alternator pulley has cut through the turbo pipe.
Its a very common fault apparently... |
8th Jul 2013 7:48am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6308 |
amazing - really basic stuff and they're still getting it wrong ??
glad it was a simple fix and no damage done (to the car that is) - confidence and incovenience, thats something else. hopefully happy motoring from here on |
8th Jul 2013 7:57am |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
Does the fix still allow the same again in another 1400miles? 1951 80" S1 2.0
8th Jul 2013 8:06am |
The Technician explained that the pipe is just poorly fitted as opposed to a poor design. However, he has reported it many times.
You can see how the pulley has cut a large hole right through the intercooler pipe... Click image to enlarge It shouldn't happen again once fitted in the right position. My concern is that air and melted bits of plastic have been able to bypass the filter and go straight into the turbo. I guess time will tell, thank god for the warranty. |
8th Jul 2013 8:16am |
Froogle-Yorkshireman Member Since: 10 Jul 2010 Location: Yorkshire Posts: 350 |
Speak to Solihull - Surely a free first service for the inconvenience Proud owner 110 Utility XS
Ex RR Sport HST V8 Ex Td5 90 |
8th Jul 2013 7:53pm |
zahy Member Since: 02 Jun 2013 Location: East Sussex Posts: 150 |
Had the same last weekend ( covering only 2500 miles from new) turned out the turbo hose had come off with the clip feel off, my local dealer fitted two clips to the hose (JUST IN CASE) according to land rover recovery LR will be releasing a modified hose/clip
8th Jul 2013 8:14pm |
Indeed it is! http://www.defender2.net/forum/topic20804.html Recently replaced mine with stainless steel hard-pipes! Was the other side that had evidience of chafing on mine....against the alternator. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
8th Jul 2013 11:26pm |
Mal, are you referring to the Entreq Airflow Kit which they produce for the Td4? If I remember well, those from Entreq are for the Puma 2.4, correct? These here: http://www.entreq.de/products-lr-defender/...r-td4.html Worth your while I guess. Several years ago I had a turbo hose split on my Puma, which was then replaced under warranty. But I would be happy to have it once and for all out of the the way. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
9th Jul 2013 4:34am |
Eric,
It is indeed those very pipes but they didn't come from Entreq. As everything from Entreq it is top quality and top dollar. But a stainless pipe with silicone ends is a stainless pipe with silicone ends. £343???? I think not!!!!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
9th Jul 2013 8:02am |
