Home > Tdi > TDI 200 Fuel Injector Pump |
cykoh85 Member Since: 25 Apr 2022 Location: Selangor Posts: 135 |
Just to confirm, the wheel bearing will give a loud sound too? Because the clunking quite loud.
4th Jul 2024 6:35am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3340 |
Correct, each wheel has 2 taper roller bearings. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
4th Jul 2024 9:43am |
Alright, Dinnu.
By the way, I captured a short video of the sounds from the rear wheel, which has a burning smell and noisy sounds coming from this area. And only when I reversed it, the clicking sounds came out. Please take a look and see if you have come across this issue before. Video Link: https://youtube.com/shorts/i7VbGExruGA Thank you. |
4th Jul 2024 12:57pm |
Hi Dinnu, do you know TDI 200 rear wheel bearing (outer) have any oil seal as showed in diagram which is no12 FRC8222?
Because only have inner oil seal there when I removed everything yesterday, so i am not sure whether is previous mechanical job or the original actually don't have the outer seal? Photo as attached showed wheel bearing broken after I removed it. Click image to enlarge |
24th Jul 2024 10:16am |
Could be that the seal was removed to lubricate the bearings with gear oil. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
24th Jul 2024 11:26am |
Oh, meaning it should have the outer seal.
Ok, noted with thanks. |
24th Jul 2024 11:38am |
Hi Bro Dinnu
Do you know where the original oil breather tank is supposed to connect? The previous owner modified it to an oil catch can, but I’ve noticed there’s always some engine oil dripping from the mini air filter (as shown in the attached photo). but I was thinking change the oil catch can system with two mini filters. Any side effect by using the oil catch can? anyway, thank you. Click image to enlarge |
14th Sep 2024 9:39am |
On 200tdi, the breather goes through a cyclone, that separates the oil mist which drains back into the sump, and the rest of the air goes back to the air intake. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
14th Sep 2024 10:32am |
15th Sep 2024 12:57pm |
