Home > Tdi > TDI 200 Fuel Injector Pump |
cykoh85 Member Since: 25 Apr 2022 Location: Selangor Posts: 138 |
Just to confirm, the wheel bearing will give a loud sound too? Because the clunking quite loud.
4th Jul 2024 5:35am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3396 |
Correct, each wheel has 2 taper roller bearings. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
4th Jul 2024 8:43am |
Alright, Dinnu.
By the way, I captured a short video of the sounds from the rear wheel, which has a burning smell and noisy sounds coming from this area. And only when I reversed it, the clicking sounds came out. Please take a look and see if you have come across this issue before. Video Link: https://youtube.com/shorts/i7VbGExruGA Thank you. |
4th Jul 2024 11:57am |
Hi Dinnu, do you know TDI 200 rear wheel bearing (outer) have any oil seal as showed in diagram which is no12 FRC8222?
Because only have inner oil seal there when I removed everything yesterday, so i am not sure whether is previous mechanical job or the original actually don't have the outer seal? Photo as attached showed wheel bearing broken after I removed it. Click image to enlarge |
24th Jul 2024 9:16am |
Could be that the seal was removed to lubricate the bearings with gear oil. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
24th Jul 2024 10:26am |
Oh, meaning it should have the outer seal.
Ok, noted with thanks. |
24th Jul 2024 10:38am |
Hi Bro Dinnu
Do you know where the original oil breather tank is supposed to connect? The previous owner modified it to an oil catch can, but I’ve noticed there’s always some engine oil dripping from the mini air filter (as shown in the attached photo). but I was thinking change the oil catch can system with two mini filters. Any side effect by using the oil catch can? anyway, thank you. Click image to enlarge |
14th Sep 2024 8:39am |
On 200tdi, the breather goes through a cyclone, that separates the oil mist which drains back into the sump, and the rest of the air goes back to the air intake. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
14th Sep 2024 9:32am |
15th Sep 2024 11:57am |
Hi Dinnu
Do you know if oil can leak through the drive flange area? The dust cap isn't broken, but when I opened it, it felt a bit loose and not tight. It's leaking again from that area, and I believe it's due to the inner hub seal. When I replaced it that day, the bearing cone wouldn't fit properly, so I forced it in with the inner hub seal. It seems the issue with the inner hub seal, after being forced, is now causing the leak. thank you. Click image to enlarge Click image to enlarge |
25th Sep 2024 4:13pm |
If you seeing oil in the red marked area, I think the dust cap is not sealing well.
Oil leaking from hub seal will wet your brake shoes/drum, and you see oil only at the brake drum lip and backing plate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
25th Sep 2024 6:26pm |
Ok, noted.
Yes, just seeing oil frm the dust cap area there. So does this mean under normal condition, some oil will travel to drive flange there for lubrication purposes? Thank you. |
25th Sep 2024 11:18pm |
On older axles, yes. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
26th Sep 2024 4:21am |
Oh i see, Ok, noted.
26th Sep 2024 2:18pm |
