Home > Maintenance & Modifications > A day in the life of Miffy the 110...
Page 55 of 60 <123 ... 545556 ... 585960>
geobloke
Yikes Screbble Rolling with laughter Rolling with laughter Do we need to set up a counselling session for Defender owners that like non-popular accessories Rolling with laughter
Post #1017280 3rd Dec 2023 4:51pm
Screbble
Mmmmm maybe so.
But maybe there are many others in the closet and we can out them, become the majority, and take over the LR world!
Whistle
Post #1017284 3rd Dec 2023 4:55pm
geobloke
Not a chance. Far too many shiny Defenders out there for us to take over the World. But, perhaps someone would buy my newly refurbished Puma XS heated seats Rolling with laughter
Post #1017286 3rd Dec 2023 4:59pm
geobloke
So the question is... Do rad muffs work?
Super old skool tech that was once a popular fix but with the advent of diesel auxiliary heaters they have somewhat gone by the wayside.
But, to those few, those lucky few that refuse the draw of "luxury", that refuse the allure of heat on tap, that would rather wear coarse horse hair long johns than spend time in an electric eurobox...
...there are radiator muffs Rolling Eyes
Yesterday morning it was a balmy -2DegC here when I set out in Miffy, rad muff down and heated seat on...
By the time I had driven 7 minutes the coolant temp was... a tad warm Rolling with laughter
Yes it works... It works really darned well... Now for the downside to a rad muff... You have to get out and raise it. Or half raised it. Super toasty warm inside the cab. Perhaps, I should have stopped earlier, but it shows that if you live in regions where the temps are consistently low. Once the muff was raised to 2/3rds height the temp dropped very quickly back to between 76-82DegC all the way through the mountains of Snowdonia.
It will be interesting to find out whether the muff helps retain the heat during slow commuter traffic as well. Not much of that around these hills, but I will find out eventually.
Coincidentally, last weekend I re-installed the speakers in the old girl after removing the AC system. Unfortunately I must have dropped the Check Temp sensor into the speaker/wiper void behind the dash as it was reading 58DegC heater air temperatures. No complaints there at all and highlights that the standard heater isn't that bad at all. What I did notice is that as I do not have the angled footwell vents in place the volume of air appears to be less restricted. Ugly but more hot air. Some might say like its driver Rolling with laughter
And to finish a few photos from a favourite ford of mine that also happens to be an excellent dog walking spot too.
Post #1017508 5th Dec 2023 11:56am
excossack
Which ford is that? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1017509 5th Dec 2023 12:12pm
geobloke
That is the Minffordd ford outside Bangor, adjacent to the disused railway leading to the old port. A nice shortcut from one side of Bangor to the other.
It has a concrete base to it and for the most part is a simple crossing, but every winter it turns into an absolute beast of a ford for a while that can wash vehicles easily down stream. The council often throw up road closed signs.
Grid: SH586706
There is also a nice little green lane between the ford and Llandagai industrial estate that comes out at the cricket ground Thumbs Up
I do like a nice ford crossing.
Post #1017518 5th Dec 2023 1:01pm
excossack
Cheers. I wonder if its on the wet roads site
*Edit* it is
https://www.wetroads.co.uk/gwynedd.htm 1999 Defender TD5 110
Regards
John M0VAZ
Post #1017529 5th Dec 2023 1:58pm
geobloke
Thumbs Up Thumbs Up Love the Wet Roads database. Unfortunately the website is now quite dated and the links have failed to work. Such a shame. Used to be able to super impose the fords into Google Earth/Maps, but that seems to have gone too.
Post #1017533 5th Dec 2023 2:17pm
excossack
Its a shame the map links don't work 1999 Defender TD5 110
Regards
John M0VAZ
Post #1017535 5th Dec 2023 2:21pm
geobloke
The physical links do not work but if you substitute the county name the pages still work
Denbighshire: http://www.wetroads.co.uk/denbighshire.htm
Thumbs Up
Post #1017536 5th Dec 2023 2:27pm
Screbble
Lovely pics πŸ‘
And as for radiator muffs - my dad had a piece of cardboard he used to β€˜stuff’ behind the grill and swore by it πŸ‘πŸ‘
Post #1017558 5th Dec 2023 8:26pm
geobloke
Honestly I have done the cardboard and the feed bag rad muff before, works a treat. Thumbs Up Thumbs Up
Post #1017561 5th Dec 2023 8:29pm
geobloke
Well I couldn't say no to any offer sent over via eBay Rolling Eyes
So Miffy now has a Far Corners rear recovery point. It needs a darned good clean and paint but it would look good in red on the rear crossmember.
The reason really for jumping on it is that whilst I have a 2" receiver I do not have a recovery adapter for it and I do not think you should recover off the internal pin. Although in a pinch you can do. I also do not have the traditional NAS rear step, but the Bowler style double rear step (with a gap above the hitch) although these pre-date the Bowler steps by years and I believe they were Dixon Fabrication items... Could be wrong there might be Whitbread fabrications...
Hear it is:
This will fit on top of the steps mounting plates, sandwiching them to the crossmember. It will also provide a middle step as it is a good boot toe deep.
I am just debating with myself whether I ditch the 2" receiver or is it one of those "just in case" things?!?! I suspect so, what would you do?
Post #1017604 6th Dec 2023 10:37am
excossack
Leave it. You know the mo you remove it, you will need it ! 1999 Defender TD5 110
Regards
John M0VAZ
Post #1017607 6th Dec 2023 11:05am
geobloke
I know I know Rolling Eyes Bow down
Post #1017611 6th Dec 2023 11:33am
