Home > Maintenance & Modifications > A day in the life of Miffy the 110... |
Yikes Screbble Do we need to set up a counselling session for Defender owners that like non-popular accessories
3rd Dec 2023 4:51pm |
Not a chance. Far too many shiny Defenders out there for us to take over the World. But, perhaps someone would buy my newly refurbished Puma XS heated seats
3rd Dec 2023 4:59pm |
So the question is... Do rad muffs work?
Super old skool tech that was once a popular fix but with the advent of diesel auxiliary heaters they have somewhat gone by the wayside. But, to those few, those lucky few that refuse the draw of "luxury", that refuse the allure of heat on tap, that would rather wear coarse horse hair long johns than spend time in an electric eurobox... ...there are radiator muffs Yesterday morning it was a balmy -2DegC here when I set out in Miffy, rad muff down and heated seat on... By the time I had driven 7 minutes the coolant temp was... a tad warm Click image to enlarge Yes it works... It works really darned well... Now for the downside to a rad muff... You have to get out and raise it. Or half raised it. Super toasty warm inside the cab. Perhaps, I should have stopped earlier, but it shows that if you live in regions where the temps are consistently low. Once the muff was raised to 2/3rds height the temp dropped very quickly back to between 76-82DegC all the way through the mountains of Snowdonia. It will be interesting to find out whether the muff helps retain the heat during slow commuter traffic as well. Not much of that around these hills, but I will find out eventually. Coincidentally, last weekend I re-installed the speakers in the old girl after removing the AC system. Unfortunately I must have dropped the Check Temp sensor into the speaker/wiper void behind the dash as it was reading 58DegC heater air temperatures. No complaints there at all and highlights that the standard heater isn't that bad at all. What I did notice is that as I do not have the angled footwell vents in place the volume of air appears to be less restricted. Ugly but more hot air. Some might say like its driver And to finish a few photos from a favourite ford of mine that also happens to be an excellent dog walking spot too. Click image to enlarge Click image to enlarge |
5th Dec 2023 11:56am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
Which ford is that? 1999 Defender TD5 110
5th Dec 2023 12:12pm |
That is the Minffordd ford outside Bangor, adjacent to the disused railway leading to the old port. A nice shortcut from one side of Bangor to the other.
It has a concrete base to it and for the most part is a simple crossing, but every winter it turns into an absolute beast of a ford for a while that can wash vehicles easily down stream. The council often throw up road closed signs. Grid: SH586706 Click image to enlarge There is also a nice little green lane between the ford and Llandagai industrial estate that comes out at the cricket ground I do like a nice ford crossing. |
5th Dec 2023 1:01pm |
Cheers. I wonder if its on the wet roads site
*Edit* it is https://www.wetroads.co.uk/gwynedd.htm 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
5th Dec 2023 1:58pm |
Love the Wet Roads database. Unfortunately the website is now quite dated and the links have failed to work. Such a shame. Used to be able to super impose the fords into Google Earth/Maps, but that seems to have gone too.
5th Dec 2023 2:17pm |
Its a shame the map links don't work 1999 Defender TD5 110
5th Dec 2023 2:21pm |
The physical links do not work but if you substitute the county name the pages still work
Denbighshire: http://www.wetroads.co.uk/denbighshire.htm |
5th Dec 2023 2:27pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
Lovely pics π And as for radiator muffs - my dad had a piece of cardboard he used to βstuffβ behind the grill and swore by it ππ |
5th Dec 2023 8:26pm |
Honestly I have done the cardboard and the feed bag rad muff before, works a treat.
5th Dec 2023 8:29pm |
Well I couldn't say no to any offer sent over via eBay
So Miffy now has a Far Corners rear recovery point. It needs a darned good clean and paint but it would look good in red on the rear crossmember. The reason really for jumping on it is that whilst I have a 2" receiver I do not have a recovery adapter for it and I do not think you should recover off the internal pin. Although in a pinch you can do. I also do not have the traditional NAS rear step, but the Bowler style double rear step (with a gap above the hitch) although these pre-date the Bowler steps by years and I believe they were Dixon Fabrication items... Could be wrong there might be Whitbread fabrications... Hear it is: Click image to enlarge This will fit on top of the steps mounting plates, sandwiching them to the crossmember. It will also provide a middle step as it is a good boot toe deep. Click image to enlarge I am just debating with myself whether I ditch the 2" receiver or is it one of those "just in case" things?!?! I suspect so, what would you do? |
6th Dec 2023 10:37am |
Leave it. You know the mo you remove it, you will need it ! 1999 Defender TD5 110
6th Dec 2023 11:05am |
I know I know
6th Dec 2023 11:33am |
