Home > Maintenance & Modifications > A day in the life of Miffy the 110...
Page 60 of 60 <123 ... 585960
geobloke
Bench
A workshop related post this morning. As some of you may know I have moved into a house that came with a 4'6" tall (or at least that is what it feels like) shed, now the Miffy shed Mr. Green It is nowhere near as good as the workshop I used to have but it is leagues and leagues better than a muddy driveway and outside slab with a vice on it.
Anyway, managed to get so shelves into it to store the parts and supplies but the area is pretty useless without something to tinker on and to mount the excellent vice.
After a good month of FB market place messages to a variety of people who apparently post up stuff they do not actually have or want to get rid of I saw an advert for a 2.5m wooden work bench reduced from £120 to free on Easter Saturday. Best of all it was pretty local to me to.
Sounded like a job for Miffy and her rood rack Thumbs Up
an hour or so round trip and a bit of lugging and shifting and duh duuuhhhhhh Bench is in the shed Mr. Green Mr. Green I can tell you that the old boy was quite the DIY grease monkey the bench is properly scarred, gnarly and impregnated with a decent amount of black oil. Perfect it will not rot away... You can even see where the old vice was mounted.
So it is in and I now need to sort out the under shelf for storage, mount the vice and somehow get light into the shed.
Anyone have any good idea for internal shed light? I do have power in there, but no light.
Post #1030165 2nd Apr 2024 9:19am
geobloke
​I also have to sort out the horrendous rain ingress problem. It completely flood that shed floor....
Post #1030166 2nd Apr 2024 9:23am
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
That's a nice looking Bench! Screwfix do some nice LED lights I have some in my Garage and there really good light and aren't mega expensive nor generate any heat 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1030168 2nd Apr 2024 9:38am
geobloke
Good call 36046 Thumbs Up I quite like the look of two of these linked to a switch
https://www.screwfix.com/p/lap-led-mains-p...240v/440kf
That'll light up the dark cave-like hovel that is the shed.
Post #1030170 2nd Apr 2024 9:45am
34064
https://www.screwfix.com/p/lap-reeve-twin-...240v/476pp
This is what I have wired into a light switch but those work lights are also pretty good and being able to move them is a massive bonus 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Post #1030172 2nd Apr 2024 9:47am
geobloke
Ah yes those also look like a good solution. Couple of those would cover the whole shed. I take it they come with just tails, no plug on the end??
Post #1030174 2nd Apr 2024 9:53am
34064
I can't remember if they come with wire it's been a few years but even so a bit of twin and earth and a plug would be fine 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Post #1030177 2nd Apr 2024 10:00am
geobloke
Marvellous. Many thanks I think that is a great solution. Thumbs Up
Post #1030179 2nd Apr 2024 10:04am
excossack
I have two of those LED lights installed in the shed. They are OK, but I find I need more light depending on what I am doing. The lights are in the apex of the roof and on two switches.
More localised light is needed for when I am on the bench 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1030181 2nd Apr 2024 10:29am
Retroanaconda
Nice bench.
You’ll never regret having too much light. I used 6 of the LED battens from Screwfix in my workshop and it’s been excellent.
Post #1030276 2nd Apr 2024 8:51pm
geobloke
Ah that is what I was pondering last night before drifting off. Need to find myself a second hand angle poise lamp Thumbs Up
Post #1030316 3rd Apr 2024 8:05am
geobloke
Retroanaconda wrote:
Nice bench.
You are quite right, there is nothing worse than too little light and there is only so much a head torch can help with dusk rapidly approaching, dinner being called and the job not quite done yet Rolling with laughter
I just realised this morning that I can now splash out on the ultimate Defender DIY luxury... There is a concrete garage pad that I have just cleaned all the debris off and goodness... I could buy a trolly jack without the fear of losing it in 8" of muddy driveway Shocked Bow down
Post #1030317 3rd Apr 2024 8:08am
geobloke
Door replacement part 1
Well it was new door day yesterday. Took me ages to get this first one done. First times are always a bit slow... Quite some time a go now I realised I had screwed up and realised that Miffys doors were beyond simple repair. I blame living close to the coast and salt spray. They have held on for longer than expected, but over the last few evenings I have almost finished the install of the drivers side second row door and, well, I am quite happy with the outcome.
From this
to this
The only issue I had was the wrong bolt size for some captive nuts (on their way and why the door furniture is not on) and I forgot to put the drain back in. Had no idea there was a drain funnel hiding away inside the second row doors...
Anyway, thankfully it is not a door off job to refit it. Just got to do the other three doors now. Tell you what though the rubber and plastic components of the original door were so hard even the flexible rubber seals which were so dry and brittle. They weren't sealing anything anymore, it is no wonder so much water and dirt got down inside.
These doors will not rust...
Post #1033024 27th Apr 2024 9:58am
