![]() | Home > Puma (Tdci) > New Airbox from Alisport |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
Do you think they would do a "group buy"? I would be interested! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Dave S Member Since: 26 Aug 2020 Location: Dungannon Posts: 76 ![]() ![]() ![]() |
Update - Andrew from Allisport emailed me to say try a genuine Land Rover MAF sensor. I had an old one I had replaced so put it on. Thus far success. The throttle response is noticeably better and the Defender is much more fun to drive. However, the chap in the video ( in my humble experience ) totally played down the difficulty of removing the old air box and associated pipework!!! I ended up cutting it all into manageable chunks. With the pipe work I used a heat gun to soften the plastic to get it out. But - seriously worth the effort.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
Certainly looks the part.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1224 ![]() ![]() ![]() |
Looks like great piece of kit. Honestly if I was to install this, it's because I like to tinker and I like quality. The performance element is a bit of a gimmick I think. Yes it will improve things at the top end of the rev range but who drives a defender at the top end. Of course after you spend all this money you will feel an improvement, because you just push that pedal a bit harder, it the placebo effect. You want a real noticeable difference you need to look at bottom end torque.
Still nice piece of kit! I wish though they would get on and making me that new cooling expansion tank they been promising me for 6 weeks.. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 683 ![]() ![]() |
That looks very niceš..
Not sure the rivits holding the latches on do it justice but that's just been fussy I supposeš I'm curious as to the filters it uses.. Are they the common vacuum cleaner filter, and if so how does it compare to rated particle size for a normal automotive filter?? I'll no doubt have a Google at some point but someone may know |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4257 ![]() ![]() ![]() |
I donāt know the exact model but these types of filters are common in trucks, excavators, ag. machinery etc. itās not a domestic hoover filter. 2007 110 TDCi Station Wagon XS
Thanks for that..š
Is anyone able to post the dimensions of their filter or the make supplied with the kit.. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Looks a nice bit of kit!
The number is on the filter in the picture. I would say the clips are riveted on so if they break, easy replacement. |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 406 ![]() ![]() ![]() |
Can anyone point me in the right direction on the Allisport site where to find this. I cant seem to locate it at all.
Thanks. |
I did try those numbers in a search but didn't come up with anything specific.. I'll check again..
The rivits in the picture I just thought looked a bit untidy next to the quality work.. Something a little more discrete.. Smaller rivits even.. Honestly it's just been picky.. I know that.. I don't think the tdci air box is on the Ali sport site yet but they will take an order if you get in touch.. Quite a wait I think.. |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 342 ![]() ![]() ![]() |
Yes as said above you need to contact them. There is a 8 to 12 week lead time. Hopefully mine is going to be shipped mid January. |
I think theyāre on back order because of demand. Youāll have to picā up the phone and call them or email.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2243 ![]() ![]() |
Has anyone asked Allisport about water ingress into their airbox, I highlighted this on page 2 of this topic as it does happen with the Nugget Stuff airbox if you have a wing side or wing top air intake and the Allisport one looks functionally the same, I.e no water separator or drain fitted.
Thanks for the replies....Ill call them.
