Home > Puma (Tdci) > New Airbox from Alisport
Page 4 of 7 <1234567>
Dave S
Northern Ireland 2012 Defender 110 Puma 2.2 XS CSW Orkney Grey
I had a very promp reply from Andrew at Allisport - his thinking is something to do with the remap. Hopefully the company which installed the remap can help - only time will tell. And yes - it's a lovely bit of kit!!
Post #1017773 8th Dec 2023 9:28am
MartinK
Do you think they would do a "group buy"? I would be interested! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #1017959 10th Dec 2023 9:37am
Dave S
Update - Andrew from Allisport emailed me to say try a genuine Land Rover MAF sensor. I had an old one I had replaced so put it on. Thus far success. The throttle response is noticeably better and the Defender is much more fun to drive. However, the chap in the video ( in my humble experience ) totally played down the difficulty of removing the old air box and associated pipework!!! I ended up cutting it all into manageable chunks. With the pipe work I used a heat gun to soften the plastic to get it out. But - seriously worth the effort.
Post #1018197 12th Dec 2023 8:30pm
jst
Certainly looks the part.
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1019805 1st Jan 2024 10:36pm
TexasRover
Looks like great piece of kit. Honestly if I was to install this, it's because I like to tinker and I like quality. The performance element is a bit of a gimmick I think. Yes it will improve things at the top end of the rev range but who drives a defender at the top end. Of course after you spend all this money you will feel an improvement, because you just push that pedal a bit harder, it the placebo effect. You want a real noticeable difference you need to look at bottom end torque.
Still nice piece of kit!
I wish though they would get on and making me that new cooling expansion tank they been promising me for 6 weeks..
Post #1019816 2nd Jan 2024 7:02am
andy63
That looks very nicešŸ‘..
Not sure the rivits holding the latches on do it justice but that's just been fussy I supposešŸ˜‚
I'm curious as to the filters it uses.. Are they the common vacuum cleaner filter, and if so how does it compare to rated particle size for a normal automotive filter??
I'll no doubt have a Google at some point but someone may know
Post #1019820 2nd Jan 2024 9:31am
Bluest
I donā€™t know the exact model but these types of filters are common in trucks, excavators, ag. machinery etc. itā€™s not a domestic hoover filter. 2007 110 TDCi Station Wagon XS
Post #1019822 2nd Jan 2024 10:20am
andy63
Thanks for that..šŸ‘
Is anyone able to post the dimensions of their filter or the make supplied with the kit..
Post #1019830 2nd Jan 2024 1:50pm
NickMc
Looks a nice bit of kit!
The number is on the filter in the picture. I would say the clips are riveted on so if they break, easy replacement.
Post #1019861 2nd Jan 2024 4:47pm
Avelingporter
Can anyone point me in the right direction on the Allisport site where to find this. I cant seem to locate it at all.
Thanks.
Post #1019862 2nd Jan 2024 4:52pm
andy63
I did try those numbers in a search but didn't come up with anything specific.. I'll check again..
The rivits in the picture I just thought looked a bit untidy next to the quality work.. Something a little more discrete.. Smaller rivits even.. Honestly it's just been picky.. I know that..
I don't think the tdci air box is on the Ali sport site yet but they will take an order if you get in touch.. Quite a wait I think..
Post #1019866 2nd Jan 2024 5:21pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Thanks.
Yes as said above you need to contact them. There is a 8 to 12 week lead time. Hopefully mine is going to be shipped mid January.
Post #1019868 2nd Jan 2024 5:39pm
NickMc
I think theyā€™re on back order because of demand. Youā€™ll have to picā€™ up the phone and call them or email.
Post #1019869 2nd Jan 2024 5:39pm
Ianh
Has anyone asked Allisport about water ingress into their airbox, I highlighted this on page 2 of this topic as it does happen with the Nugget Stuff airbox if you have a wing side or wing top air intake and the Allisport one looks functionally the same, I.e no water separator or drain fitted.
Ianh wrote:
Note: one issue that some have encountered when changing out the old airbox and intake pipe for a nugget one is during heavy rain moisture, in some cases a lot of water, gets into the airbox and soaks the filter and builds up in the bottom of the airbox ( a very bad thing).
This happens if the standard side or wing top is used for the new air intake pipe as there is no water separator or airbox drain fitted. As the Alisport solution does not have a moisture separator or airbox drain this could also cause moisture / water ingress during heavy rain.
The solution is to fit an RAI / snorkel with a cyclonic filter at the top.
So something to think on and ask Alisport about
Post #1019876 2nd Jan 2024 6:28pm
Avelingporter
Thanks for the replies....Ill call them.
Post #1019877 2nd Jan 2024 6:35pm
