![]() | Home > Puma (Tdci) > New Airbox from Alisport |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2243 ![]() ![]() |
I don’t think I’ve ever got to 4200 revs in my 2.2.... oh no, that means I’m officially old
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 224 ![]() ![]() ![]() |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3394 ![]() ![]() |
![]() Click image to enlarge ![]() |
So if the graphs are correct, then technically you can get circa 38BHP more, however that’s at circa 4200 revs ! And that’s not where you would be changing gear . So a bit of unnecessary over marketing in my view.
Where you are more likely to change gear , especially in 1st to second and second to 3rd is 2500 - 2700 revs, and the difference here looks to be circa 5-8 BHP. From the graph that seams to be where the most torque is as well, which bears out when you would do those gear changes. In my mind it looks to be a nice solution , I like the way it uses the existing brackets, I like the way the filter is clamped as it gives adjustment to differing manufacturers filter sizes which can vary in length by 5mm or so even if they are quoted as the same fit ( the nuggetstuff one does not have an adjustment in the filter clamping and is an issue ), I like the (cheaper) option to have the intake pipe in the same position as the original airbox so you can use nuggetstuff or nakatanenga pipes if you already have them or prefer them. It looks easy to remove as well which helps when working on other components in that area. My experience with the nuggetstuff v2 airbox , with nakatanenga intake hose, bas intercooler and silicon hoses is the vehicle performs much better and I expect the alisport solution would perform the same or even better with that even larger filter. It is not anything like getting a map, or gaining 38BHP and lots more torque where it’s needed , but you will feel the improvement even on a standard map. Note: one issue that some have encountered when changing out the old airbox and intake pipe for a nuggetstuff one is during heavy rain moisture, in some cases a lot of water, gets into the airbox and soaks the filter and builds up in the bottom of the airbox ( a very bad thing). This happens if the standard side or wing top is used for the new air intake pipe as there is no water separator or airbox drain fitted. As the Alisport solution does not have a moisture separator or airbox drain this could also cause moisture / water ingress during heavy rain. The solution is to fit an RAI / snorkel with a cyclonic filter at the top. So something to think on and ask Alisport about |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 866 ![]() ![]() |
Thank you. |
Why would you not be changing gear at the top of the rev range?
HP = torque x rpm / 5252 If you want power, then you generally need revs. That is just the way it works. If you don't rev an engine already, then power mods are unlikely to help at all by and large. As nearly all modding moves the curve to the right as a rule.
38hp is a MASSIVE gain, in percentage and raw numbers. Esp considering the amount of power the engine makes standard. |
Worth a read https://www.defender2.net/forum/topic32669-15.html especially the post by Pete at Bell auto services.
This is for a mapped setup, I find that with my standard map but with the nuggetstuff box and nakatanenga air intake pipe on normal use on a flat road I change at circa 2700rpm which lands on 2nd or 3rd gear at circa 2000- 2200 rpm, so close to the peak torque point and in the rev hang sweet spot Pete highlights. Note before I fitted the airbox and pipe I changed at circa 3k revs , but now find circa 2700 to do the same with the new setup including the BAS intercooler.Given the Alisport is very similar in design I expect a similar result. That’s why I, and I expect most 2.4 / 2.2 puma owners don’t shift at 4200 revs or anywhere near it in normal driving. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Anyone running the td5 air box? Is it worth the money?
No but I do really really want it...
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 917 ![]() ![]() ![]() |
I have one on my 90. It’s a stunning bit of kit, but not cheap. It has an ITG filter and there is definitely an increase in the intake NVH. I had it fitted at the same time as a VNT, so I can’t really gauge how much of a difference it has made on its own. It’s just looks nice if nothing else. ![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Ah ha... What's the intake diameter Baron? It doesn't say in the blurb.
I have a feeling it’s the same size as the factory airbox, however I have a silicone adapter so I can run 4” pipework to the wing. Charlie
Interesting. I would have thought they'd have increased the diameter a bit. Thanks Baron.
I expect they’ve tried to make an application for the widest market. Charlie
