![]() | Home > Puma (Tdci) > New Airbox from Alisport |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17705 ![]() ![]() ![]() |
A centrifugal precleaner is a better idea, but difficult if you want to keep the wing intake.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Yeah it’s the wing ductwork that is the real squeeze, I have a VNT to go on mine and want to upgrade while it’s apart. I’m out of touch with who does what I I don’t read the LR “Mags” they’re just a big advert |
Almost the same setup as yours: Nugget Stuff intake & airbox, BAS remap, and Alive intercooler, and I also experience much, much better throttle response. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
I have a Nak large-bore RAI leading to a Nuggetstuff filter and the throttle response and 'liveliness' is streets ahead of the standard arrangement, and ahead of the traditional Mantec-style RAI.
I have no doubt that is the case. They do look like they are standard size inlets. Still they are beautiful... |
LET'S OFF-ROAD Member Since: 05 Jun 2022 Location: Green Laning Posts: 66 ![]() ![]() |
This is brilliant news, finally a decent alternative to the standard box as Nugget Stuff no longer make their alloy box.
I'll be ripping out my Nugget V3 as soon as the Allisport one arrives. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2243 ![]() ![]() |
Nugget stuff don’t make anything any more as the owner (Wayne aka “Nugget” ) is now retired and closed the business.
Well that's also good news because the V3 was not a well made item.
I received my Allisport airbox yesterday and it looks to be of high quality and a bargain at £340 compared to the Nugget Stuff box too. The air filters to fit the Allisport box are also cheap to replace and a common item rather than only being able to get ones that fitted properly from Nugget for £60. |
Defintitely need photos of your install
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 342 ![]() ![]() ![]() |
Would like to see your install. Mine is on back order as there seems to be a huge demand for these. Hopefully will get mine in mid January.
Dave S Member Since: 26 Aug 2020 Location: Dungannon Posts: 76 ![]() ![]() ![]() |
After reading this thread I ordered one of the air boxes for my 2012 2.2 Tdci Defender. It arrived yesterday and was fitted. On my first test drive I got about 500 yards down the road and my engine management light came on and the vehicle went into limp mode. Checked air flow sensor and tried again - same thing. The vehicle has an Alive remap and upgraded intercooler. Rang Allisport and was told that's never happened before and was given an email address for their tec department. I am awaiting a reply.
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 683 ![]() ![]() |
What was the specific fault code generated and are their any other details on your air intake system.. Ie standard or raised
Andy
I've yet to get the Defender to a garage to have fault codes read but will let you know when I do. The air intake was standard. |
Cheers dave.. There was another thread a day or so ago about a mass air flow sensor fault.. It didn't involve the install of the system you have but equally odd..
No fault with air filter removed but a fault when it was installed.. .. I don't think any resolution to that has been posted yet.. Hope yours is quickly resolved.. Its a lovely looking air box👍 |
