![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2957 ![]() ![]() |
Thank you l've turned off the seatbelt bong
I also turned off the auto fold mirrors but now they won't fold with the buttons on the inside of the door door either I guess that will have to do, you can fold them by hand. lt's just that when towing, the extension door mirrors hit the door when the mirrors fold. |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 246 ![]() ![]() |
Has anyone changed engine configuration from 250 to 300. I believe they are the same engines and that it is only software difference
Try it and see what happens. You can always change it back if there's any issues.
I’m not sure where the settings are to try it in the gap tool software, can anyone advise and I will try it?
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
Be warned if you change the engine power using the IID tool! If you do it the system records a permanent fault which will show up if you car is scanned by the dealers computer, it shows up as a power mismatch so your dealer will know that something has been done. JLR retrofits originally offered this change but stopped as it was being overwritten by dealers, they then started to re-offer it along with a software hack to prevent the dealer from seeing it, but it doesn't appear on their website anymore so maybe they have stopped again.
![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I made a seperate post about the working activations here https://www.defender2.net/forum/post1006773.html?#1006773
I've asked Martin to make it a sticky at the top of this section of the forum but please keep all the discussion in this thread. ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks Martin for making it a sticky thread
So does it actually work, that is, do you get the extra 50bhp and extra torque? lf that's the case no wonder LR don't like it, my D250 cost £3,000 more than the same specification vehicle with the D200 !! £3,000 just for changing a setting.....that's easy money |
Resix Member Since: 20 Aug 2023 Location: Lisbon Posts: 2 ![]() ![]() |
Hi Roccobarocco, Did you keep using the D300 with a diferente speed limit ? My D300 cuts out at 197km/h 2023MY What ccf did you change ? Cheers |
xrp86 Member Since: 07 Sep 2023 Location: mcallen Posts: 4 ![]() ![]() |
has anyone turned off the DLR with the gap tool? I was able to turn them off during the day, but when the headlights turn on they do too. One of my led dlr is broken
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 111 ![]() ![]() |
I think JLR refers to the leds as Signature LEDs, and uses those as DLR, ie the LEDs are more than DLR. I think that’s why they are brighter when DLR are on and dimmer when used with headlights.
Yes, signature led, I have searched all kinds of ways on ccf and cannot find the option
mani_jeenu Member Since: 07 Sep 2023 Location: Melbourne Posts: 12 ![]() ![]() |
can you add these as well? These are all from this thread as well except the last two which are from different threads in this forum Foglight with HighBeam EUCD-018 Foglight Function Foglight without restrictions MultiCAN-734 Front Fog Lights Oft High Beam. Set to Disable. ------------------------------------ More accurate speed reading MultiCAN-838 from: Speedo market 0- 3.5% + 2kph To Speedo market 1- 2.0% + 0kph ------------------------------------ Tow Assist2 MultiCAN-579 Tow Assist Set to Tow Assist 2 MultiCAN-635 Towing Set to Not Support if not already set to this setting. MultiCAN-696 ATCM TA2 Switch Set to Tow Assist 2 feature selection switch not fitted, again if not already set to this. MultiCAN-793 TA2 Input Control Set to HVAC rotary. MultiCAN-795 TA2 Select in FCPB Set to Rotary used for selection within touch screen. --------------------------------------- After retrofitting 11.4" display MultiCAN-641 FrntUpperDispVariant Alpine 11.6 inch Single View -------------------------------------- After retrofitting ClearSight Interior Rear View Mirror MultiCAN-711 Interior Mirror Variant IRVM changed to SVRM |
MultiCAN-838 from: Speedo market 0- 3.5% + 2kph To Speedo market 1- 2.0% + 0kph l've noticed that my speedometer over reads by about 3mph at 70 mph, according to my GPS. This would be useful then. Why would they set the speedometer to over read? |
