Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 108 of 110 <123 ... 107 108109110>
kenl
Australia
I ended up doing the manual reset with the door and the bonnet, nice to have an alternative actually. MY23.5 SE Defender
Post #1057910 19th Jan 2025 9:57pm
tooth_dr
Northern Ireland
Has anyone got theirs recalibrated to D300 yet using GAP? I’ve about every other thing activated and thinking that surely the remap must be possible too. But then again if it was then why has nobody sussed it out yet and posted online.
Post #1058626 26th Jan 2025 10:05am
rabalam
United States 2016 Defender 110 Other Experience LE Auto Santorini Black
Soft Buttons on sidebar interface
@northeye
Once you enable this feature for a soft touch, how do you activate it or configure your PIVI screen to show the softkeys?
Thanks
Post #1059034 30th Jan 2025 9:26pm
northeye
Japan
Reboot the Pivi system with press and hold the off/volume button for 20 seconds.
Post #1059054 31st Jan 2025 12:52am
DC-Defender
United States
Anyone notice any additional options in the CCF file since installing the latest Pivi Pro 4.3.0 update?
Post #1060905 19th Feb 2025 3:44am
rabalam
@northeye
I have an interesting issue. I'm not sure this is why it's not working.
The below is the module you posted in the original post.
* MultiCAN-898 Rear Htd Screen Soft Button
from "Not Fitted" to "Soft Button Fitted"
The ACTUAL module on the GAPTool is:
* MultiCAN-898 Read Htd Screen Soft Button
Could this be the issue? I cannot find the original "rear" module. I've up dated my Gaptool to the latest firmware.
Post #1060958 20th Feb 2025 3:11am
northeye
Japan
"read Htd Screen" is correct.
But it means "rear heated screen", I believe.
Post #1060959 20th Feb 2025 6:20am
rabalam
@northeye,
Okay thanks, it must be my LR633 then, I've done the hard reset on the Pivi and still no soft buttons. I'll keep searching though.
~r
Post #1060997 20th Feb 2025 6:22pm
Colin68
These are the ones i changed. May depend on your model and year. Mine is a MY25
MultiCAN-892 SideBar Climate
Climate Icon on Side Bar Available - FICP Replacement
MultiCAN-896 ReCircle Soft Button
Soft Button Fitted with timed and latched logic
MultiCAN-897 Max AC Soft Button
Soft Button Fitted
MultiCAN-897 Max Defrost Soft Button
Soft Button Fitted
MultiCAN-897 AC OnOff Soft Button
Soft Button Fitted
MultiCAN-897 Auto Climate Soft Button
Front AUTO Climate Soft Button Fitted
MultiCAN-898 Front Htd Screen Soft Button
Soft Button Fitted
Soft Button Fitted
Post #1061015 21st Feb 2025 8:11am
TC909
I've read the GAP IID G4 is setup to your VIN on first use.
What happens when you sell the car, can you set it up on a new vehicle then?
Post #1061017 21st Feb 2025 9:40am
pjeski
United States
You can add a vehicle or transfer the tool.
https://www.gap-diagnostic.com/faq/
Post #1061019 21st Feb 2025 10:13am
rabalam
@colin68
I see you did not modify the;
"* MultiCAN-882 Sidebar Controls
from "Legacy" to "Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i""
Is this not required?
thanks,
~r
Post #1061052 21st Feb 2025 7:53pm
OVRLANDR
United States
I had to make the change from “Legacy” to “Sidebar Controls with DSC + VC Drawer and VC Bar on 4x4i” on MultiCAN-882 in order for the sidebars to show.
I have a MY25.
Post #1061225 24th Feb 2025 3:16pm
OVRLANDR
United States
I have a MY25.
Post #1061226 24th Feb 2025 3:16pm
norland
Can't say I see side bars cluttering up the screen as an improvement when the car has real physical controls...
Post #1061234 24th Feb 2025 4:50pm
