Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1423 |
Done Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
8th Sep 2023 7:43am |
I would say that just about every car that I've had the speedo over-read they do this to ensure that they comply with the law and make sure that their speedometers are never showing less than true speed under any foreseeable circumstances, car manufacturers will normally deliberately calibrate their speedos to read 'high' by a certain amount. I always set my ACC to the speed limit plus 2mph so in a 40 limit I would set the ACC to 42 Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
8th Sep 2023 7:46am |
Badeagle Member Since: 27 Aug 2022 Location: London Posts: 54 |
Got my IID tool up and running
Have already added the 007 splash screen, walk up / away locking, Wi-Fi hot spot, open tailgate with fob and dynamic mode so far (love the red dials). Would like the ACC when it’s sorted. Has anyone been able to get the car to remember last drive mode. MY23 XS 110 D250 2003 Jeep Cherokee Limited |
8th Sep 2023 9:53pm |
No not yet unfortunately Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
8th Sep 2023 10:47pm |
aajr Member Since: 18 Dec 2022 Location: San Diego Posts: 33 |
It worked on a 2023.5. |
9th Sep 2023 6:54am |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 108 |
What is “last drive mode” and what worked?
9th Sep 2023 7:34am |
I took it to mean if you had the car in say dynamic it would remember it after switching the car off. Cheers Ian
9th Sep 2023 8:03am |
Great can you share the settings MY23 XS 110 D250 2003 Jeep Cherokee Limited |
9th Sep 2023 10:10am |
Yes it would be good to know the settings if you could share them please Cheers Ian
9th Sep 2023 12:33pm |
I find it odd what the car remembers and what it doesn’t. This once certainly should be remembered. My car retains the setting for mute for the navigation voice prompts, but forgets that I set the voice feedback accent to English (UK), it always reverts back to US. |
9th Sep 2023 12:41pm |
It remembers your setting for the auto shutoff when stopping at a light, etc So, if the auto shutoff was on, it will remember that next time you use the car. |
9th Sep 2023 4:28pm |
Oh I see you mean stop/start setting MultiCAN-566 MHLastUserMode, we thought you'd found a way for the car to remember the drive mode you were in eg Eco/Comfort/Dynamic etc Cheers Ian
9th Sep 2023 6:02pm |
Sorry for the confusion. Alas, I have not seen anything that allows keeping the drive mode from the prior setting.
9th Sep 2023 8:28pm |
TBinOz Member Since: 09 Sep 2023 Location: Queensland Posts: 3 |
Successfully enabled Configurable TR on my 2021 D300 SE. It was reluctant to show up on screen, even after running the learn config procedure and letting the car sit double-locked overnight I still had to force-reboot Pivi Pro. Showed up in the end though.
Thanks to all who helped discover and share these options! |
10th Sep 2023 9:08pm |
