Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 49 of 110 <123 ... 484950 ... 108109110>
pjeski
United States
lightning wrote:
UPDATE
Downloaded the new firmware and all
working now.
Couple of questions though, for those more in the know.
Where is the option to stop the door open "bong"? And can you switch off the seatbelt one as well?
And why does it say currently "no cruise control" as it does have cruise. Does it mean no adaptive cruise control?
Thanks !
I don’t know about the door bong, but:
MultiCAN-717 Front Belt Minder
Beltminder Fully OFF
MultiCAN-737 Rear Belt Minder
Rear Beltminder OFF
The cruise control one just may not apply. mine says it too:
EUCD-023 Cruise Control
Without cruise control
Post #1006732 6th Sep 2023 7:40pm
lightning
Thank you l've turned off the seatbelt bong
I also turned off the auto fold mirrors but now they won't fold with the buttons on the inside of the door door either
I guess that will have to do, you can fold them by hand. lt's just that when towing, the extension door mirrors hit the door when the mirrors fold.
Post #1006737 6th Sep 2023 8:04pm
DefenderMidlands
Has anyone changed engine configuration from 250 to 300. I believe they are the same engines and that it is only software difference
Post #1006739 6th Sep 2023 8:26pm
lightning
Try it and see what happens. You can always change it back if there's any issues.
Post #1006745 6th Sep 2023 8:45pm
DefenderMidlands
I’m not sure where the settings are to try it in the gap tool software, can anyone advise and I will try it?
Post #1006762 6th Sep 2023 9:35pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Be warned if you change the engine power using the IID tool! If you do it the system records a permanent fault which will show up if you car is scanned by the dealers computer, it shows up as a power mismatch so your dealer will know that something has been done. JLR retrofits originally offered this change but stopped as it was being overwritten by dealers, they then started to re-offer it along with a software hack to prevent the dealer from seeing it, but it doesn't appear on their website anymore so maybe they have stopped again. Confused If anybody still wants to change it have a look at MultiCAN-580 Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1006772 6th Sep 2023 10:22pm
Hairy Dan
I made a seperate post about the working activations here https://www.defender2.net/forum/post1006773.html?#1006773
I've asked Martin to make it a sticky at the top of this section of the forum but please keep all the discussion in this thread. Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1006774 6th Sep 2023 10:30pm
Hairy Dan
Thanks Martin for making it a sticky thread Bow down Cheers Ian
Kielder 4x4 Safari
Post #1006775 6th Sep 2023 10:40pm
lightning
So does it actually work, that is, do you get the extra 50bhp and extra torque?
lf that's the case no wonder LR don't like it, my D250 cost £3,000 more than the same specification vehicle with the D200 !!
£3,000 just for changing a setting.....that's easy money
Post #1006793 7th Sep 2023 9:51am
Resix
Portugal
roccobarocco wrote:
I just joined your group and wish to participate in this discussion. Don't have a Defender yet but it's coming. However, we own also a MY23 Discovery D300, so I started fiddling a bit around with Gap IID which works splendidly. I did the Wifi and the key away locking feature. Works nice (-:
Today I tried to unlock the speed limiter from factory setting 209km/h to the new value of 225km/h, it works but it gives me an error that collision warning is not working and the cruise control is without function, anyone has an idea how to mitigate this problem?
Many wishes
roccobarocco
TIA
Hi Roccobarocco,
Did you keep using the D300 with a diferente speed limit ? My D300 cuts out at 197km/h 2023MY
What ccf did you change ?
Post #1006802 7th Sep 2023 11:39am
xrp86
United States
DaytimeRuningLights
has anyone turned off the DLR with the gap tool? I was able to turn them off during the day, but when the headlights turn on they do too. One of my led dlr is broken
Post #1006826 7th Sep 2023 8:39pm
pjeski
United States
I think JLR refers to the leds as Signature LEDs, and uses those as DLR, ie the LEDs are more than DLR. I think that’s why they are brighter when DLR are on and dimmer when used with headlights.
Post #1006833 7th Sep 2023 9:00pm
xrp86
United States
Yes, signature led, I have searched all kinds of ways on ccf and cannot find the option
Post #1006841 7th Sep 2023 9:42pm
mani_jeenu
Australia
can you add these as well? These are all from this thread as well except the last two which are from different threads in this forum
Foglight with HighBeam
EUCD-018 Foglight Function
Foglight without restrictions
MultiCAN-734 Front Fog Lights Oft High Beam.
Set to Disable.
More accurate speed reading
MultiCAN-838 from: Speedo market 0- 3.5% + 2kph
To Speedo market 1- 2.0% + 0kph
Tow Assist2
MultiCAN-579 Tow Assist
Set to Tow Assist 2
MultiCAN-635 Towing
Set to Not Support if not already set to this setting.
MultiCAN-696 ATCM TA2 Switch
Set to Tow Assist 2 feature selection switch not fitted, again if not already set to this.
MultiCAN-793 TA2 Input Control
Set to HVAC rotary.
MultiCAN-795 TA2 Select in FCPB
Set to Rotary used for selection within touch screen.
After retrofitting 11.4" display
MultiCAN-641 FrntUpperDispVariant
Alpine 11.6 inch Single View
After retrofitting ClearSight Interior Rear View Mirror
MultiCAN-711 Interior Mirror Variant
IRVM
changed to SVRM
Post #1006866 8th Sep 2023 6:05am
lightning
l've noticed that my speedometer over reads by about 3mph at 70 mph, according to my GPS.
This would be useful then.
Why would they set the speedometer to over read?
Post #1006877 8th Sep 2023 8:13am
