Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 48 of 110 <123 ... 474849 ... 108109110>
pjeski
United States
aajr wrote:
pjeski wrote:
I tried MultiCAN-514 StopStartInhibitIcon to Stop Start Inhibited Icon disabled (Non-CFSS), hoping to get the icon off the cluster while my auto stop start is inhibited, but that did something other than I wanted if it did anything.
I wonder if you set this to enabled it makes it go away? The way it is written, it seems to me that enabled means it is inhibited.
Enabled was the default, and I changed it to disabled. Either way, no difference I could see.
Post #1006296 3rd Sep 2023 2:37am
aajr
United States
Interesting. I looked at my settings and it shows disabled (and of course still shows the icon) on my car, so I was hoping enabling it would make it go away.
Post #1006306 3rd Sep 2023 6:53am
lightning
l finally got to connect the GAP tool today with my Defender D250
Everything worked okay including registration.
It connects with my ipad and reads all the various ECU's. The vehicle identification comes up and everything looks good.
However when l try to select "vehicle config" the loading starts and then stops with "reading CCF wBackup" and then l get "operation failed E O"
The other menu items seem to work okay.
How can l proceed from here? l tried shutting down the vehicle and restarting. l got through all the loading procedures and then the same screen when l try to select "vehicle config"
Have l missed a step somewhere?
Post #1006370 3rd Sep 2023 5:15pm
NoWayMe
Canada
aquascape, mmbanf, MickD, Hairy Dan, thanks you guys all for the suggestions and support!! After going through everything again I finally got it working! You guys are the best! Mr. Green
Post #1006376 3rd Sep 2023 5:29pm
lightning
Great that yours is working.
Mine isn't !!
Post #1006386 3rd Sep 2023 6:51pm
aajr
United States
What's you car battery voltage? Might try connecting it to a charger and letting it sit for a minute or drive it for a few miles and try again. All modern cars are super sensitive to low voltage.
If that fails, I also suggest downloading the lastest harware version for the IID tool, assuming you haven't downloaded it within the last week.
Post #1006387 3rd Sep 2023 8:23pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Are you using the latest firmware on your device, there was a problem with a few people and Patrick updated the firmware so make sure you update. Failing that drop Patrick an email. Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1006399 4th Sep 2023 12:01am
lightning
Thank you for the heads up.
l managed to update the firmware last night so will try again today to connect it to the vehicle. l'll report back when l've done it.
Post #1006420 4th Sep 2023 9:07am
stevemfr
France
Thanks Ian! Thumbs Up
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1006448 4th Sep 2023 11:45am
lightning
lt may be worth posting a summary of things that can be changed and the file numbers, l was looking for the door open chime cancel and after searching fifteen pages of this thread l still haven't found it, although l know l read it somewhere.
Post #1006643 6th Sep 2023 9:38am
Cheshire110
+1. It would be good if we can have a location with all of the known & working options.
Every so often someone posts a summary but it quickly gets buried. Cheers, David
Post #1006644 6th Sep 2023 9:40am
Resix
Portugal
Hey everyone, thanks for all the inputs on here !
Got my IIDtool activated and have done this:
MultiCAN-777 Ter Dyn Select In FCPB
Standard: Control interface not available in FCPB
Changed to: Rotary used for selection within touch screen
EUCD - 245 Dynamic 1 set to “Dynamic 1 Content with Configurable Dynamic Mode Screen”
MultiCAN - 562 DynamicProgMode. Set to “Available for Selection Without Timeout”
MultiCAN - 605 ConfigDynamicMode. Set to “Fitted”
MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout”
MultiCAN - 777 Ter Dyn Select In FCPB. Set to “rotary used for selection within touch screen”
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
Closed and locked car 4 times with more the 30 minutes and no Dynamic mode anywhere.
2023MY D300X
Any ideias ? Should I reset the Pivi system ?
Post #1006651 6th Sep 2023 10:01am
pjeski
United States
Yes.
Post #1006653 6th Sep 2023 10:23am
lightning
This has been asked before, but was never answered.
What happens if you change the engine from "D250" to "D300" in vehicle configuration?
l assume the software is not present to actually upgrade performance, but you never know.
lt is only software that determines the engine output.
Post #1006714 6th Sep 2023 5:17pm
lightning
UPDATE
Downloaded the new firmware and all
working now.
Couple of questions though, for those more in the know.
Where is the option to stop the door open "bong"? And can you switch off the seatbelt one as well?
And why does it say currently "no cruise control" as it does have cruise. Does it mean no adaptive cruise control?
Thanks !
Post #1006723 6th Sep 2023 6:16pm
