Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 5 of 110 <123 456 ... 108109110>
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
pllr wrote:
Few questions:
1. Did you apply each change individually? Or did you do everything at once (e.g., 007, Wifi hotspot, and Dynamic Mode)?
Personally I do them all at once, I also created a list of things that I have been testing. To create a list you can click on the star next to the parameter and give your list a name Thumbs Up
pllr wrote:
2. I read earlier in the thread that folks were having difficulty with Adaptive Cruise Control. Has anyone figured that out yet?
I have ACC from the factory but I do know a couple of people are still having problems with it. Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #972448 26th Nov 2022 2:35pm
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
For those trying to get ACC that don't currently have it, here's what I have tried so far without real success. These are changes I made comparing my CCF file to Ian's.
Setting: Value [Original Value]
EUCD-075 Integrated Vehicle Dynamic Control: IVDC (Incl. Enhanced ESP And CDC) [Not Supported]
EUCD-097 Forward Collision Warning: Not Supported [Without Forward Collision Warning]
MultiCAN-503 IntelCruiseCtrl: Not supported [ICC not Fitted]
MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted [Normal Cruise Fitted]
I did verify that even my Base model has the radar module behind the Land Rover logo. You can even test it with the IID tool in Live Values. So, the hardware is in place, just not the settings/software.
For those that have ACC, do you also have regular cruise control as well? The videos and documentation I've seen so far hint at switching between Speed Limiter/ACC and not regular cruise control. I'm wondering if disabling regular cuise may help...IDK. 20MY Defender 110 Fuji White
Post #972454 26th Nov 2022 4:19pm
Dicky1961
Yep for your info , I have the factory fitted ACC and also the regular CC and speed limiter. Thumbs Up
Post #972455 26th Nov 2022 4:30pm
Ritson
France
Can anybody clarify what, if any, impact tweaking your CCF files has on your vehicle warranty? Do subsequent OTA PIVI updates reset any changes made back to the original settings? Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue
Post #972458 26th Nov 2022 4:50pm
matt4x4
Germany
@pllr
I did both. First one by one, then tried a complete restore - which worked without problemns - after messing around with acc stuff. After that I set all the above changes in one try -> all ok.
@Hairy Dan
After applying the 3 settings above the tacho and odometes turn red in dynamic mode, like
on your first screen. Also the "inner premium lights" turn red then.
After messing up ACC features I always got an error shown with the emergency braking system,
was not able to use even the normal cruise control. After restore all fine again.
Post #972463 26th Nov 2022 5:11pm
matt4x4
Germany
Don't know what will be with the warranty, but after using the restore function
from IIDtool the car is back to original parameters.
I did changes when on Pivi Version 3.2.1 - got an update to 3.3.0 last night -
afterwards the changes (Wifi, Dynamic) are still active
Post #972464 26th Nov 2022 5:17pm
matt4x4
Germany
Would you mind sharing an dump of your ccf (the mail which can be send from the app),
so I can diff it with mine.
Post #972465 26th Nov 2022 5:18pm
Dicky1961
“Matt4x4 Would you mind sharing an dump of your ccf (the mail which can be send from the app),
so I can diff it with mine.”
I’ve tried doing this for HairyDan before, I can’t seem to get a copy of the CCF files for some reason.
Post #972468 26th Nov 2022 5:25pm
Ritson
France
Ok that's good to know, hopefully someone can clarify the warranty question Current: MY22 P400e SE
Post #972473 26th Nov 2022 5:51pm
Hairy Dan
matt4x4 wrote:
@Hairy Dan
Interesting Confused my interior lights go red but not the dials
Check your PM's Cheers Ian
Kielder 4x4 Safari
Post #972483 26th Nov 2022 6:50pm
forzahog
matt4x4 wrote:
@pllr
Could you share what changes you tried for ACC?
I have been looking at the CCF for anything related to this list.
https://www.lrdefender.org/speed_control_d...n-630.html
Quote:
The adaptive cruise control system utilizes the following main components:
CCM
IPMA
Parking Aid sensors (quantity 8)
Park Assist sensors (quantity 4)
Side Obstacle Detection Control Module - Left (SODL)
Side Obstacle Detection Control Module - Right (SODR)
Right steering wheel switch
PCM
Electric throttle
ABS
Adaptive cruise control warning indicator - Displayed in the IPC.
Post #972492 26th Nov 2022 7:33pm
pllr
United States
matt4x4 wrote:
@pllr
@Hairy Dan
Thanks for the response. Looks my GAP tool won't show up until at least Monday. Looking forward to using it.
Post #972520 26th Nov 2022 11:10pm
pllr
United States
forzahog wrote:
matt4x4 wrote:
@pllr
CCM
IPMA
Parking Aid sensors (quantity Cool
PCM
Electric throttle
ABS
We have a 2022 L663 (US/NAS) with Adaptive Cruise and a 2023 L663 (US/NAS) without Adaptive Cruise. I'm looking to add it to the 2023. For those that have tried this, do you see screens like this in your Settings > Vehicle section?
(In my 2022 with Adaptive Cruise [with 3.3.1. Pivi Pro software], I can go to Settings > Vehicle > Driver Assistance > Cruise and Limiter and then get a few options for Adaptive Cruise. I'm curious if you need to turn something on in this menu after updating the CCF file.)
Post #972522 26th Nov 2022 11:15pm
forzahog
My MY20 doesn't show the ACC options on that screen, just the Speed Limiter options. I am running an older version of pivi currently, it's slowly updating to newer versions, but my latest is 3.2.0.
Side note, I was also playing with saving Start/Stop so it doesn't keep resetting to on when you get back in the car.
MultiCAN-566 MHLastUserMode = Enabled
That's the setting that saves your last state. So far, it's been working today.
I would be interested in seeing the difference between the CCF files between ACC/Non-ACC. Ian provided me his and I think I've made progress, but we have very different model versions. 20MY Defender 110 Fuji White
Post #972523 26th Nov 2022 11:26pm
pllr
United States
@forzahog, I will post the stock CCF files for both our 2022 P400 SE and 2023 P300 as soon as I get the tool (and figure out how to do it).
The 2022 has Adaptive Cruise and the Wifi Hotspot, but I don't think the 2023 has any other different "software" features. The 2022 has the premium interior lighting, but I assume that's a hardware thing. Other features are definitely hardware (e.g., HUD, fridge, power steering column, etc.).
I personally spec'd and ordered the 2022 P400 SE (the first car I ever ordered!) with pretty much every available option except for towing (because I don't tow). The 2023 is a JLR spec'd NAS 30th Anniversary Edition which is based off a P300S with all of the same off-road options plus towing.
Post #972526 26th Nov 2022 11:45pm
