Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 4 of 110 <123 45 ... 108109110>
MattF
United States
Is there a detailed "Getting Started" with the tool and beta anyplace? I'd love to join
Thank you
Matt
Post #972138 23rd Nov 2022 2:06pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
You can download the manual from here
https://www.gap-diagnostic.com/support/documents/IIDTool/
If you already have the tool drop Patrick at Gap ( https://www.defender2.net/forum/member-patgapinnov.html ) a line and ask to be added onto the beta test. If you are buying an IID tool just make sure it is the Gen 3 one which is the latest.
There are some videos on Youtube about using the IID tool but none that I can find specific to the new Defender
https://www.youtube.com/results?search_que...land+rover
The support from Gap and Patrick in particular is second to none and you can also ask any questions in here and I'm sure somebody will be able to help you Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #972151 23rd Nov 2022 4:05pm
Hairy Dan
Matt, you will need 3 posts before you can use the PM's on this site Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #972152 23rd Nov 2022 4:06pm
pllr
United States
I've ordered the BT tool and have downloaded the app. For folks who have used this and been successful with certain features...
1. Is it obvious how to do it? For example, I want to activate the Wifi Hotspot. Is that a Yes/No? Or is there a combo of features that need to be turned on?
2. Ditto for Dynamic Mode. Is it one flag? Or do multiple things need to be turned on/off?
If it's OK to share a screenshot, please do! Smile
Post #972184 23rd Nov 2022 9:12pm
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
When you go into car config, you're given a list of possible values each time you open a setting. Most of the time it's something like "Enabled" or "Disabled"..."Fitted" or "Not Fitted". Other times it's a list of known possible values with more detail.
You'll get the hang of it. Just be careful what you change...I've had a few close calls where I basically bricked it for a while. Shocked The good thing is that the IID tool makes a backup of your first ccf load and you can restore back if needed. phew! 20MY Defender 110 Fuji White
Post #972193 23rd Nov 2022 11:17pm
matt4x4
Germany
Hey folks.
Getting my IIDtool hopefully tomorrow.
Drive a D250 XS MY23.5, Pivi Software still on version 3.2.1
All Terrain Progess Control and Terrain Respone Automatic 2 and Terrain Response Configurable
was in the Offroadplus package, which my car has.
It has also the advanced tow assist from factory
So I might help, with an "original" cff dump were these could be looked after.
I bought the car "on site", so not my individual config.
So I'm missing Adaptive Cruise Control and I'm really interessted to get it to work, if the
radar sensor is build in (hopefully).
But I think I'll start with some simple things...
Wifi Hot Spot and Dynamic Mode + Dynamic config
As I read, these are "simple hacks"
Other things I like to look after are:
- get the Start/Stop configurable, so it stays in the last selected mode.
- get the rear door unlock AND pop open with the fob, now it only unlocks
Greetings
Matt
Post #972233 24th Nov 2022 3:15pm
Louis-C
Is there anyone in the South that would be happy to activate some features for me in exchange for payment?
Post #972240 24th Nov 2022 4:05pm
Hairy Dan
Louis-C the IID tool is locked to one VIN so you can't activate things on other peoples cars unless you buy the IID Pro tool. The Pro tool is rather expensive and I'm not sure whether GAP have released a beta for the pro tool yet Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #972245 24th Nov 2022 4:44pm
Hairy Dan
To give you an idea of how to modify settings this is a very easy one, it enables the 007 James Bond start up screen which was on the 007 Defenders. It's a bit naff and only stays on the screen for a couple of seconds but this will give you some idea of how the tool works Thumbs Up
 Cheers Ian
Kielder 4x4 Safari
Post #972392 25th Nov 2022 6:46pm
BruceT
South Africa
It would be so cool if we could personalise the display. Would love my logo to be on it. I’m sure someone will crack it eventually.
On a separate note, I have tow assist. Terrain progress, and the fancy cruise control, sorry I forget all the fancy names. What else is there?
I have been thinking of ordering one of these tools. Mine is a 23MY d300 HSE xdynamic which I’ve just got
Thank you "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce
11MY Defender 130
23MY Defender 110 D300 HSE X-Dynamic
https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA
Post #972407 25th Nov 2022 8:39pm
pllr
United States
Thanks! That was really helpful to see.
Just so I'm really clear: (1) Upload CCF; (2) turn the car off for 15 min; (3) and manually reboot Pivi. Right?
Post #972412 25th Nov 2022 11:03pm
Hairy Dan
Yes that's correct, after your have uploaded the modified CCF file, disconnect the IID tool and switch the car off, lock it up and leave it for approx 15 mins. Some people have their activations appear without having to reboot Pivi, but on mine they do not appear until I have done the reboot so I left that step in. When you first plug your tool into the car the app takes a back-up of your original CCF file so you always have a way back to standard if you need it. Please bear in mind that the software is still in Beta so somethings may not work at the moment and everything is done at your own risk but if anything does go wrong Patrick at Gap provided 1st class support. Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #972414 25th Nov 2022 11:33pm
matt4x4
Germany
Before everyone sits in the car with the mobile phone for hours to scroll and look at the
possible features/values, we perhaps get a list of possible features/values together ...
Here is a start with the features I changed so far ...
- Activate WIFI/WLAN Hotspot
Feature: MultiCAN-814 IVIWiFiHotspot
Standard: Not fitted
Changed to: Internal WiFi Hotspot fitted
- Change Splash Screen to "Defender 007"
EUCD-205 Racing Sub Brand
Standard: Mainstream Vehicle
Changed to: LTD 007
- Dynamic Mode
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted
Post #972428 26th Nov 2022 10:28am
pllr
United States
@matt4x4, this is great. Thank you so much!
My device was supposed to be delivered today, but it looks like it may be delayed a couple of days. If I figure anything else out, I will contribute to the list.
Few questions:
1. Did you apply each change individually? Or did you do everything at once (e.g., 007, Wifi hotspot, and Dynamic Mode)?
2. I read earlier in the thread that folks were having difficulty with Adaptive Cruise Control. Has anyone figured that out yet?
Post #972442 26th Nov 2022 1:41pm
Hairy Dan
Great idea matt4x4 Thumbs Up
When people have enabled Dynamic mode do there clocks/dials look like this?
I get the centre part on mine but no red on the dials
This is my centre dash
 Cheers Ian
Kielder 4x4 Safari
Post #972446 26th Nov 2022 2:29pm
