![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1443 ![]() ![]() ![]() |
Another one that may or may not work is walk away locking
MultiCAN-505 WalkAwayLocking Change it to Current: Enabled You then have to go into your centre screen and enable it ![]() Click image to enlarge Patrick said that this doesn't work on all cars and mine happens to be one that it doesn't work on ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Has anyone managed to find the setting for disabling the auto shutdown?
I hate when you open the door and the car turns itself off, erasing any terrain response modes etc. (NB. I’m NOT talking about start/stop) Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
umbertob Member Since: 21 Jun 2020 Location: Altadena, CA Posts: 133 ![]() ![]() |
Mine doesn't work either. As a matter of fact, the setting in the center screen that appears under the Safety and Security tab, as you show in the above screenshot, turns off by itself about 5 seconds after I toggle it on. So, I suspect Walk Away Locking may be market or model year dependent. Same reason why I cannot seem to get Global Windows Close to operate on my 2020. In North America / US market, that features is disabled, and even if you turn toggle both Global Windows Open and Close on in the center screen settings, only Open works with the remote Changing the setting in the CCF has not made a difference for me. Perhaps there is another setting I am missing. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround |
matt4x4 Member Since: 18 Nov 2022 Location: North Posts: 16 ![]() ![]() |
The link to the doc is very interesting. HairyDan send me his CCF. Both of us have these parameters set: MultiCAN-792 DADC Module DADC LL MultiCAN-793 CCM Variant MRRevo14F Fitted I think this refers to the radar in the LR sign and the camera behind the center mirror. So I believe the hardware must be there and the same. I tried with these settings, but will try again with variations. As said, I got "Emergency brake failure" and nothing worked with CC. EUCD-023 Cruise Control Without cruise control -> a lot values - tried: Adaptive Cruise Control, Stop & Go, Brake Limit 2, With ACC To CC Toggling -> but Hairy Dans CCF also shows "without", but he has it. -> so I dont know, what this setting really is for. Possible Values: Adaptive Cruise Control Adaptive Cruise Control Stop & Go Adaptive Cruise Control Brake Limit 2 Adaptive Cruise Control Stop & Go, Brake Limit 2 Adaptive Cruise Control, With ACC To CC Toggling Adaptive Cruise Control, Stop&Go, With ACC To CC Toggling Adaptive Cruise Control, Brake Limit 2, With ACC To CC Toggling ->Adaptive Cruise Control, Stop & Go, Brake Limit 2, With ACC To CC Toggling MultiCAN-503 IntelCruiseCtrl Not supported ->ICC fitted MultiCAN-580 PTCruiseFitment Normal cruise fitted Values: No cruise fitted Normal cruise fitted ACC fitted ->ACC with Queue Assist fitted Others I found are the MultiCAN-497 settings. I tried changing them, but without any success. These are my defaults. IntelSpdLimitISL ISL fitted DrvDrowsyMonDDM DDM not fitted IntelEmergBrkingCUIEB IEB not fitted FwdCollWarnAEB FCW not fitted But I have some kind of "Forward Collision warning" working, if not messing it up with changing paramaters - hmmmmm.... As seen on the screens in "pllr"s post I have as standard the "Adaptive Speed limiter" for traffic signs and "Emergeny brake" with the 4 possible value in pivi (far to near) under "Collision avoidance" But not the "Adaptrive cruise control: Stop Gab" menu - yet ![]() So I think all needed hardware must be there. We'll see what the sunday brings .... |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 275 ![]() ![]() |
Walk away locking only works on 2023 MY with the new BCM., according to Vulkan. So if your fuel cap doesn’t lock, walk away locking should. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Thanks for that, now I know why it doesn't work on mine
Mine is a 23.5
WalkAwayLocking works for me. And my car has no locking fuel cap. But I like to retrofit it sometime, if I get the actuator. Or will that not work with the new BCM? Can the new BCM also be the reason why enabling ACC does not work / gives the error with emergency braking assist ? |
I’ve got the new BCM on my 23 MY and I’ve had ACC added by Venture Automotive in Bolton.
Vulkan have developed an add on unit for fuel locking but it is both expensive and difficult to fit. Simon at Powerful is also looking at it. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 298 ![]() ![]() |
My March build 23MY V8 doesn’t have the locking filler flap. As far as I can see the flap has the actuator fitted and wiring connected so it seems like it’s more about saving chips in the BCM.
And yes, Simon is on the case and also with some other retrofits. I’ve just installed his sunglasses holder. Bit fiddly but looks and works fine. |
Enabled this on my car last night and it seems to work ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Just to keep the list up to date and together, here are the changes that appear to work at the moment.
- Activate WIFI/WLAN Hotspot MultiCAN-814 IVIWiFiHotspot Standard: Not fitted Changed to: Internal WiFi Hotspot fitted - Change Splash Screen to "Defender 007" EUCD-205 Racing Sub Brand Standard: Mainstream Vehicle Changed to: LTD 007 - Dynamic Mode EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted -Remember Stop/start setting MultiCAN-566 MHLastUserMode = Enabled -WalkAwayLocking MultiCAN-505 Change it to Current: Enabled Only available on MY2023 onward, if you don’t have a locking fuel cap you can enable walk away locking. You will also have to go into your centre screen setting and switch it on -Modify signature LEDs behavior MultiCAN-463 DRLBehWhilstDIsAct Current: Turn Off New: No Action MultiCAN-465 DRLBehWhHazardsAct Current: Turn Off New: No Action This setting is to keep them on while the turn signals or hazard lights are operating. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 67 ![]() ![]() ![]() |
I can add one more to the list for those that don't already have it. The subwoofer was installed in my base model, but wasn't enabled.
EUCD-121 Subwoofer Standard: Without Subwoofer Changed to: Subwoofer 20MY Defender 110 Fuji White |
And another one...
-Enable All Microphones EUCD-126 Microphone = Four Microphones (Two Front & Two Rear) Standard: Microphone (Driver Only) This one switched from using the microphone in the dash to the four mounted overhead. This made a huge impact on sound quality when I was on the phone. 20MY Defender 110 Fuji White |
PatGAPInnov Site Sponsor Member Since: 19 Jan 2015 Location: Montreal Posts: 45 ![]() ![]() |
Darn, I should have spent more time on this thread... Glad to see progress so far!
We still haven't figured out Adaptive Cruise Control but to our defense have been overwhelmed with work lately. We will get to the bottom of it in time... Cheers! http://www.gap-diagnostic.com/ ![]() ![]() ![]() |
