Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1421 |
Personally I do them all at once, I also created a list of things that I have been testing. To create a list you can click on the star next to the parameter and give your list a name
I have ACC from the factory but I do know a couple of people are still having problems with it. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
26th Nov 2022 1:35pm |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 |
For those trying to get ACC that don't currently have it, here's what I have tried so far without real success. These are changes I made comparing my CCF file to Ian's.
Setting: Value [Original Value] EUCD-075 Integrated Vehicle Dynamic Control: IVDC (Incl. Enhanced ESP And CDC) [Not Supported] EUCD-097 Forward Collision Warning: Not Supported [Without Forward Collision Warning] MultiCAN-503 IntelCruiseCtrl: Not supported [ICC not Fitted] MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted [Normal Cruise Fitted] I did verify that even my Base model has the radar module behind the Land Rover logo. You can even test it with the IID tool in Live Values. So, the hardware is in place, just not the settings/software. For those that have ACC, do you also have regular cruise control as well? The videos and documentation I've seen so far hint at switching between Speed Limiter/ACC and not regular cruise control. I'm wondering if disabling regular cuise may help...IDK. 20MY Defender 110 Fuji White |
26th Nov 2022 3:19pm |
Dicky1961 Member Since: 25 Mar 2022 Location: South Yorkshire Posts: 145 |
Yep for your info , I have the factory fitted ACC and also the regular CC and speed limiter.
26th Nov 2022 3:30pm |
Ritson Member Since: 11 Apr 2021 Location: France Posts: 187 |
Can anybody clarify what, if any, impact tweaking your CCF files has on your vehicle warranty? Do subsequent OTA PIVI updates reset any changes made back to the original settings? Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
26th Nov 2022 3:50pm |
matt4x4 Member Since: 18 Nov 2022 Location: North Posts: 16 |
Don't know what will be with the warranty, but after using the restore function from IIDtool the car is back to original parameters. I did changes when on Pivi Version 3.2.1 - got an update to 3.3.0 last night - afterwards the changes (Wifi, Dynamic) are still active |
26th Nov 2022 4:17pm |
Would you mind sharing an dump of your ccf (the mail which can be send from the app), so I can diff it with mine. |
26th Nov 2022 4:18pm |
“Matt4x4 Would you mind sharing an dump of your ccf (the mail which can be send from the app),
so I can diff it with mine.” I’ve tried doing this for HairyDan before, I can’t seem to get a copy of the CCF files for some reason. |
26th Nov 2022 4:25pm |
Ok that's good to know, hopefully someone can clarify the warranty question Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
26th Nov 2022 4:51pm |
Interesting my interior lights go red but not the dials
Check your PM's Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
26th Nov 2022 5:50pm |
Could you share what changes you tried for ACC? I have been looking at the CCF for anything related to this list. https://www.lrdefender.org/speed_control_d...n-630.html 20MY Defender 110 Fuji White |
26th Nov 2022 6:33pm |
pllr Member Since: 22 Nov 2022 Location: PA Posts: 24 |
Thanks for the response. Looks my GAP tool won't show up until at least Monday. Looking forward to using it. |
26th Nov 2022 10:10pm |
We have a 2022 L663 (US/NAS) with Adaptive Cruise and a 2023 L663 (US/NAS) without Adaptive Cruise. I'm looking to add it to the 2023. For those that have tried this, do you see screens like this in your Settings > Vehicle section? (In my 2022 with Adaptive Cruise [with 3.3.1. Pivi Pro software], I can go to Settings > Vehicle > Driver Assistance > Cruise and Limiter and then get a few options for Adaptive Cruise. I'm curious if you need to turn something on in this menu after updating the CCF file.) |
26th Nov 2022 10:15pm |
My MY20 doesn't show the ACC options on that screen, just the Speed Limiter options. I am running an older version of pivi currently, it's slowly updating to newer versions, but my latest is 3.2.0.
Side note, I was also playing with saving Start/Stop so it doesn't keep resetting to on when you get back in the car. MultiCAN-566 MHLastUserMode = Enabled That's the setting that saves your last state. So far, it's been working today. I would be interested in seeing the difference between the CCF files between ACC/Non-ACC. Ian provided me his and I think I've made progress, but we have very different model versions. 20MY Defender 110 Fuji White |
26th Nov 2022 10:26pm |
@forzahog, I will post the stock CCF files for both our 2022 P400 SE and 2023 P300 as soon as I get the tool (and figure out how to do it).
The 2022 has Adaptive Cruise and the Wifi Hotspot, but I don't think the 2023 has any other different "software" features. The 2022 has the premium interior lighting, but I assume that's a hardware thing. Other features are definitely hardware (e.g., HUD, fridge, power steering column, etc.). I personally spec'd and ordered the 2022 P400 SE (the first car I ever ordered!) with pretty much every available option except for towing (because I don't tow). The 2023 is a JLR spec'd NAS 30th Anniversary Edition which is based off a P300S with all of the same off-road options plus towing. |
26th Nov 2022 10:45pm |
