![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1440 ![]() ![]() ![]() |
You could try
Advanced Towing MultiCAN-505 TowingAero Not supported --> Fitted MultiCAN-579 TowAssist Tow Assist 2 MultiCAN-635 Towing Not supported --> Fitted Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3015 ![]() ![]() |
Anyone figured out the procedure to disable the auto fold mirrors yet?
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 86 ![]() ![]() |
Great info. I will give that all a try and report back on the findings. Was planning on looking through all the CCF’s to see what I could find. Will start with those. |
MickD Member Since: 28 Jul 2023 Location: New England Posts: 28 ![]() ![]() |
This got me close but it's still not working. I get the icon for tow assist now, but when I enter the tow assist screen it says "Reserved" and the start button is disabled. It may not look like it in the photo but the start button is not selectable. ![]() Click image to enlarge |
kenl Member Since: 11 Jul 2022 Location: bunvegas Posts: 30 ![]() ![]() |
Do you need to have a trailer attached? MY23.5 SE Defender
Yes. You can't get to that screen unless you have a trailer attached.
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 ![]() ![]() |
Same issue here as MickD
There is another setting
MultiCAN-696 ATCM TA2 Switch Tow Assist 2 feature selection switch not fitted But I haven't looked to see what the options for that are, unfortunately I haven't got a trailer here to test Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks for the help, I hadn't seen that setting. When you search within the app it only returns results where the keyword is in the setting description and not the values.
I enabled both of these and unfortunately it's still the same. MultiCAN-696 ATCM TA2 Switch Tow Assist 2 feature selection switch not fitted MultiCAN-696 ATCM Rotary Switch ATCM Rotary Switch not fitted I left all of the changes activated. It seems some settings take a sleep cycle to take effect. I'll post back if it magically starts working. |
Still a work in progress then
![]() I don't know whether you know or not but if you don't want to scroll through all the options when sitting in the car you can email a complete ccf list to yourself. Check the video I made below. I have printouts of my CCF file and compare them to other ones that people have sent to me, so I can look for any changes. I use a mac and a programme called Kaleidoscope which lets you compare two or more files and highlights the differences. ![]() Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I didn't know, that's helpful, thanks!
You have exactly the same as I had when I tried over the weekend. What I find interesting is I had that result with just making the change to MultiCAN 579. I went and looked today to see about changing 505 and 635 and I did not find them listed in my CCF files. I will look again later but I am pretty sure they are not there which I find interesting. I have added the new suggestions to my list and will try them soon as well along with looking through all my CCF’s to see what else I can find. |
If you are missing entries make sure you click on this
![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I was wondering if that was maybe the case. This is new to me so still learning. Should have asked. I was planning on looking back at the instruction manual on the unsupported function. Will give it a try.
