Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 37 of 110 <123 ... 363738 ... 108109110>
ODPA
United States
Hairy Dan wrote:
In my notes I have
MultiCAN579 TowAssist 0x02
Change to
Tow Assist 2
But I haven't been able to test it personally as I haven't got a trailer here, let us know if it works Thumbs Up
Perfect, that is great. I will set it and this weekend give it a try. My wife’s 130 has it stock have used it before and think it is great. Will let you know.
As a second note I added dynamic mode this morning and WiFi hotspot. Both are working great. Here is a list of the changes I made for dynamic mode. I have the holy grail of dashes. Lol. Red lights and dash and a noticeable difference in vehicle behavior. I also am able to select dynamic mode with the dial, I do not have to select by touching the pivi screen. Love the GAP tool so far. Now onto my wife’s 130.
EUCD - 245 Dynamic 1 set to “Dynamic 1 Content with Configurable Dynamic Mode Screen”
MultiCAN - 562 DynamicProgMode. Set to “Available for Selection Without Timeout”
MultiCAN - 605 ConfigDynamicMode. Set to “Fitted”
MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout”
MultiCAN - 777 Ter Dyn Select In FCPB. Set to “rotary used for selection within touch screen”
Post #1001786 25th Jul 2023 9:19pm
haymeister
Japan
What does 'Dynamic mode' give you apart from red dials?
Heavier steering, a more sensitive throttle response, holds the gears longer? 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #1001794 26th Jul 2023 1:12am
ODPA
United States
I think you hit most of it. It also will hold gears no matter the RPM when in sport mode and adds three new windows to the pivipro. Stopwatch, lap timer, and g force. My 110 also has the heads up display which changes to MPH and a tachometer indicator.
Post #1001797 26th Jul 2023 5:04am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Yes somebody pointed that out last week and when I went to my settings I had it set correctly but had been told you had to touch the screen to do it so never checked Laughing Whistle Embarassed Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1001842 26th Jul 2023 2:12pm
Hairy Dan
As ODPA says you have pretty much hit the nail on the head with your description although not everybody gets the red dials Big Cry I now have the flappy paddles enabled on mine and that in conjunction with dynamic mode changes the way I drive the car Twisted Evil Whistle Cheers Ian
Kielder 4x4 Safari
Post #1001843 26th Jul 2023 2:16pm
DefenderMidlands
Has anyone managed to enable the cooling seats on cars with the heated seats and got it working with this tool?
Post #1001927 26th Jul 2023 10:23pm
Hairy Dan
There was somebody on here looking to retrofit the cooled seats but I don't think he went ahead because of the hardware that was needed. I'm pretty sure I've seen the setting for the climate seats in the CCF file so you should be able to turn them on once the hardware is fitted. Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1001932 26th Jul 2023 11:55pm
Nuclear Nick
Also stiffens the suspension and deeper slightly louder exhaust note. But it’s standard on the V8 so it also has the necessary hardware.
Post #1001956 27th Jul 2023 8:55am
DefenderMidlands
Where in the gap tool are the settings to see if I could add an activity key? I read that I need to check if the kvm is locked for life? I’m not sure where to find this though?
Post #1002102 28th Jul 2023 4:58pm
whiterdesign
I think you will find if you have 2 keys that it is locked, they only left it open when the vehicles were being delivered with one key, enabling them to add the second key later, it would then have been locked 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #1002107 28th Jul 2023 5:19pm
DefenderMidlands
I am aware of that and do have two keys. As I have the gap tool I just thought I would have a look but couldn’t see in the tool settings where to check
Post #1002108 28th Jul 2023 5:36pm
MickD
United States
Hello, new guy here.
I was just activating Dynamic mode on my 110 using the instructions posted earlier in this thread.
It was all working except that the dynamic mode icon was not appearing on the drivers display when adjusting the rotary knob to select a mode.
I found that adding this did the trick:
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
Here's an image to demonstrate. Adding EUCD-129 resolved the issue.
Post #1002128 28th Jul 2023 11:55pm
ODPA
United States
MickD nice info on EUCD129 I didn’t include that on my post as it was already active on my 110. I had it listed as a possible change but no change was needed once I was in the CCF files and saw my current settings.
Post #1002131 29th Jul 2023 4:33am
ODPA
United States
Well no joy on the Advanced Tow Assist. I tried setting to Tow Assist 2 which looked like it was working. Gave me the icon for the trailer with the steering wheel after selecting my trailer profile. Then when in reverse I could get the start window but the system would not allow me to select start. Then when I would exit out it would say auto steering cancelled but when backing the dial did nothing other than change the temperature setting. I have advance tow assist on the 130 so am familiar with how it works. Going to let it sit a while and see if it magically changes. If not I will put it back to default setting. Will have to dig more into it later.
Post #1002227 30th Jul 2023 1:09am
MickD
United States
You got further than I did. I also set Tow Assist 2 but got nothing. Maybe I needed a Pivi reset.
Post #1002231 30th Jul 2023 4:44am
