Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 38 of 106 <123 ... 373839 ... 104105106>
ODPA
United States
I got what I reported after a Pivi reset. Going to have to look around some more and see what else might be involved. I also tried assist 3 which was not it at all.
Post #1002232 30th Jul 2023 4:11am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
You could try
Advanced Towing
MultiCAN-505 TowingAero
Not supported --> Fitted
MultiCAN-579 TowAssist
Tow Assist 2
MultiCAN-635 Towing
Not supported --> Fitted Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1002302 30th Jul 2023 5:31pm
lightning
Anyone figured out the procedure to disable the auto fold mirrors yet?
Post #1002304 30th Jul 2023 5:34pm
ODPA
United States
Hairy Dan wrote:
You could try
Advanced Towing
Tow Assist 2
MultiCAN-635 Towing
Great info. I will give that all a try and report back on the findings. Was planning on looking through all the CCF’s to see what I could find. Will start with those.
Post #1002334 31st Jul 2023 1:22am
MickD
United States
Hairy Dan wrote:
You could try
Advanced Towing
Tow Assist 2
MultiCAN-635 Towing
This got me close but it's still not working. I get the icon for tow assist now, but when I enter the tow assist screen it says "Reserved" and the start button is disabled. It may not look like it in the photo but the start button is not selectable.
Post #1002394 31st Jul 2023 1:15pm
kenl
Australia
Do you need to have a trailer attached? MY23.5 SE Defender
Post #1002473 31st Jul 2023 10:56pm
MickD
United States
Yes. You can't get to that screen unless you have a trailer attached.
Post #1002474 31st Jul 2023 11:09pm
Nicofender
Germany
Same issue here as MickD
Post #1002494 1st Aug 2023 11:04am
Hairy Dan
There is another setting
MultiCAN-696 ATCM TA2 Switch
Tow Assist 2 feature selection switch not fitted
But I haven't looked to see what the options for that are, unfortunately I haven't got a trailer here to test Cheers Ian
Kielder 4x4 Safari
Post #1002518 1st Aug 2023 1:08pm
MickD
United States
Thanks for the help, I hadn't seen that setting. When you search within the app it only returns results where the keyword is in the setting description and not the values.
I enabled both of these and unfortunately it's still the same.
MultiCAN-696 ATCM Rotary Switch
ATCM Rotary Switch not fitted
I left all of the changes activated. It seems some settings take a sleep cycle to take effect. I'll post back if it magically starts working.
Post #1002556 1st Aug 2023 4:37pm
Hairy Dan
Still a work in progress then Confused
I don't know whether you know or not but if you don't want to scroll through all the options when sitting in the car you can email a complete ccf list to yourself. Check the video I made below.
I have printouts of my CCF file and compare them to other ones that people have sent to me, so I can look for any changes. I use a mac and a programme called Kaleidoscope which lets you compare two or more files and highlights the differences. Thumbs Up
 Cheers Ian
Kielder 4x4 Safari
Post #1002559 1st Aug 2023 4:58pm
MickD
United States
I didn't know, that's helpful, thanks!
Post #1002560 1st Aug 2023 5:02pm
ODPA
United States
MickD wrote:
Hairy Dan wrote:
You could try
Advanced Towing
Tow Assist 2
MultiCAN-635 Towing
You have exactly the same as I had when I tried over the weekend. What I find interesting is I had that result with just making the change to MultiCAN 579. I went and looked today to see about changing 505 and 635 and I did not find them listed in my CCF files. I will look again later but I am pretty sure they are not there which I find interesting. I have added the new suggestions to my list and will try them soon as well along with looking through all my CCF’s to see what else I can find.
Post #1002632 2nd Aug 2023 3:55am
Hairy Dan
If you are missing entries make sure you click on this
 Cheers Ian
Kielder 4x4 Safari
Post #1002735 2nd Aug 2023 3:09pm
ODPA
United States
I was wondering if that was maybe the case. This is new to me so still learning. Should have asked. I was planning on looking back at the instruction manual on the unsupported function. Will give it a try.
Post #1002745 2nd Aug 2023 4:14pm
