Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1415 |
You could try
Advanced Towing MultiCAN-505 TowingAero Not supported --> Fitted MultiCAN-579 TowAssist Tow Assist 2 MultiCAN-635 Towing Not supported --> Fitted Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
30th Jul 2023 5:31pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2770 |
Anyone figured out the procedure to disable the auto fold mirrors yet?
30th Jul 2023 5:34pm |
ODPA Member Since: 06 Jul 2023 Location: Northwest Posts: 86 |
Great info. I will give that all a try and report back on the findings. Was planning on looking through all the CCF’s to see what I could find. Will start with those. |
31st Jul 2023 1:22am |
MickD Member Since: 28 Jul 2023 Location: New England Posts: 28 |
This got me close but it's still not working. I get the icon for tow assist now, but when I enter the tow assist screen it says "Reserved" and the start button is disabled. It may not look like it in the photo but the start button is not selectable. Click image to enlarge |
31st Jul 2023 1:15pm |
kenl Member Since: 11 Jul 2022 Location: bunvegas Posts: 27 |
Do you need to have a trailer attached? MY23.5 SE Defender
31st Jul 2023 10:56pm |
Yes. You can't get to that screen unless you have a trailer attached.
31st Jul 2023 11:09pm |
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 |
Same issue here as MickD
1st Aug 2023 11:04am |
There is another setting
MultiCAN-696 ATCM TA2 Switch Tow Assist 2 feature selection switch not fitted But I haven't looked to see what the options for that are, unfortunately I haven't got a trailer here to test Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
1st Aug 2023 1:08pm |
Thanks for the help, I hadn't seen that setting. When you search within the app it only returns results where the keyword is in the setting description and not the values.
I enabled both of these and unfortunately it's still the same. MultiCAN-696 ATCM TA2 Switch Tow Assist 2 feature selection switch not fitted MultiCAN-696 ATCM Rotary Switch ATCM Rotary Switch not fitted I left all of the changes activated. It seems some settings take a sleep cycle to take effect. I'll post back if it magically starts working. |
1st Aug 2023 4:37pm |
Still a work in progress then
I don't know whether you know or not but if you don't want to scroll through all the options when sitting in the car you can email a complete ccf list to yourself. Check the video I made below. I have printouts of my CCF file and compare them to other ones that people have sent to me, so I can look for any changes. I use a mac and a programme called Kaleidoscope which lets you compare two or more files and highlights the differences. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
1st Aug 2023 4:58pm |
I didn't know, that's helpful, thanks!
1st Aug 2023 5:02pm |
You have exactly the same as I had when I tried over the weekend. What I find interesting is I had that result with just making the change to MultiCAN 579. I went and looked today to see about changing 505 and 635 and I did not find them listed in my CCF files. I will look again later but I am pretty sure they are not there which I find interesting. I have added the new suggestions to my list and will try them soon as well along with looking through all my CCF’s to see what else I can find. |
2nd Aug 2023 3:55am |
If you are missing entries make sure you click on this
Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
2nd Aug 2023 3:09pm |
I was wondering if that was maybe the case. This is new to me so still learning. Should have asked. I was planning on looking back at the instruction manual on the unsupported function. Will give it a try.
2nd Aug 2023 4:14pm |
