Home > My Defender > 1988 Shire Blue Landrover 90 Restoration
Page 22 of 28 <123 ... 212223 ... 262728>
Dinnu
A bit more progress.
Right inner mudguard fitted so can fit expansion tank.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967763 15th Oct 2022 4:32pm
Co1
Looking incredibly clean! Nice work!
Post #967773 15th Oct 2022 6:09pm
Dinnu
Thanks Col. It is many many hours of cleaning Embarassed but the parts done a while back need a good dusting now Laughing 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967774 15th Oct 2022 6:23pm
Dinnu
Turned my attention to the front calipers. I have actually set a target that by Christmas it should be able to move forward under its own power, so it also need to stop. Will be far from finished, but will be a milestone which I hope is reachable.
So I ended up splitting the calipers, this way the bores can be inspected and cleaned better.
So some pictures in order: after 24hrs in the electrolysis bath dissolved most of the rust, but still needed a quick over with the wire brush. I have zinc plated them (no pic for that) and etch primed them. Have used the old pistons and the wipers to mask the bores.
Post #968212 18th Oct 2022 6:12pm
Dinnu
Calipers ready, need to sort the short rigid pipe from caliper to flexi hose. The original ones are ok, but the nuts are a bit rusty. Checked the genuine ones.. but pricey for what they are Shocked Big Cry
On to the prop shafts. All good except one cross that showed a bit of play, so that is replaced.
And painted a few more bits.
Post #968671 22nd Oct 2022 9:19pm
Dinnu
Today I sat down behind the steering wheel of my 90 for the first time in more than 4 years. I was like a kid again on those kiddie rides 😂. Cannot describe my smile 😃
And ohhh my, the steering, the seating, and everything felt so different (and spacious) compared to the Puma Shocked Perhaps the lack of doors, windscreen and roof, but the steering wheel and dash felt so far away.
Post #969315 29th Oct 2022 6:52pm
Screbble
Enjoy it - you deserve a little bit of harmless fun after all your hard work. Thumbs Up
Did you make engine noises whilst turning the steering wheel from side to side? Laughing
Post #969371 29th Oct 2022 10:55pm
Dinnu
Hahaaha, yes, and shifting through the gears Laughing Laughing
Although the gear stick is still not installed. But the imagination was there Embarassed 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #969379 30th Oct 2022 6:46am
JOW240725
Fantastic! Well done you!! Thumbs Up James
Instagram @suffolk_rovers
Post #969397 30th Oct 2022 9:49am
Dinnu
Cheers James. Thank you. Wink 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #969403 30th Oct 2022 10:28am
Dinnu
Got the hard brake lines, from the G valve all the way to the rear slave cylinders, and the short ones on the front calipers done locally,. Collected today Thumbs Up .
Made a quick tool to straighten the coiled uneven pipes, and worked really well. Now I need to build a bender, as the one I have creates a larger radius of curvature compared to the original lines. Then all that is needed is paint them green, just like how the originals were Smile
In case anyone wonders how the straightening tool works, the upper 2 bearings are fixed. Their ID is 10mm, perfect fit on M10 bolts. The lower bearing has an ID of 12mm, and use an M8 bolt. In between the M8 molt and the bearing race, I turned an M8 nut eccentrically, which threads on the bolt, and support the bearing. So by adjusting the spanner position on the M8 bolt, I can move the lower bearing upwards or downwards. So it was just a matter of trial and error adjusting the spanner back and forth until I was happy with the straightness of the lines. I kept 2 small pieces of wood to keep the tube centered on the bearings (I was keeping the lines down with my thumb). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #969688 1st Nov 2022 8:15pm
Dinnu
Had a little knob moment...
When I had purchased the 90, replaced the gear knob (probably original was already falling off), and installed the gear knob that can be see on the left. I do not know the provenance of this knob, but have a feeling it came out of a Range Rover.
Decided to go back to the original knob.
Fitted the left inner mudguard... now waiting for delivery for some parts so the wheels can be fitted - but will stay on axle stands to avoid flat spots.
Post #970941 13th Nov 2022 7:58am
Co1
Those galv inner wheel arches look very smart indeed! Nice to see the build coming together Dinnu, great work as always.
Post #970943 13th Nov 2022 8:17am
Dinnu
Thanks Col. The original inner mudguards were re galvanized. I only show the best part of the galvanizing Embarassed , as the way the mudguards were hung for the zinc dip, some zinc pooled inside the mudguard. But it adds some extra protection Cool 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #970955 13th Nov 2022 12:04pm
JOW240725
You won't get flat spots, you'll have it running about before then!! Thumbs Up Bow down James
Post #970956 13th Nov 2022 12:17pm
