Home > My Defender > 1988 Shire Blue Landrover 90 Restoration
Page 21 of 28 <123 ... 202122 ... 262728>
JOW240725
Right, you need to stop with this beachside and get going again!! I'm missing the updates! Very Happy Bow down James
Instagram @suffolk_rovers
Post #961621 14th Aug 2022 4:01pm
Dinnu
Yeah, I should Smile 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #961651 14th Aug 2022 9:02pm
Dinnu
So here is the original bumper that has been galvanized. Plus a few small parts.
Decided to paint the radiator. The new radiator is aluminum, but I prefer a black radiator on an old Land Rover, just as they used to be when they were made from copper. After taking this photo, I realized that the headers need some cleaning (I masked them).
Post #963059 27th Aug 2022 2:53pm
Co1
Bumper looks tidy. How much have you got left to do on the resto now?
Post #963073 27th Aug 2022 6:02pm
JOW240725
Agree... need to see this finished soon! Going to be amazing! Great work!! James
Post #963075 27th Aug 2022 6:10pm
Dinnu
Thanks. I literally polished the bumper before taking it to being hot dipped. Unfortunately the guys were very busy, so they did not pay very good attention and there are some dull lines on it, I guess the lift from the zinc bath was not so smooth.
Well, regarding body panels still need to do the windscreen frame and hinges, the rear side panels, which I got a spare set that will be cut to fit sliding windows (I will be keeping the original panels intact), the rear door, which needs a fair amount of welding Mad , and the roof.
Mechanically, a few parts still to assemble to finish off the engine, mainly timing belt cover and water pump to install, and alternator that needs a good clean up and service and PAS pump. Still need to do both swivels for front axle, calipers which I am hoping to service, and refurbish the prop shafts. And install rear brakes (shoes, slave cylinders and pipes from G valve backwards).
Does not sound like a lot, but the speed that I am going with... might take a little while Embarassed
I think the small little stuff will slow the progress even further. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #963078 27th Aug 2022 6:49pm
JOW240725
As much as we want to see it finished don't rush it now!! Thumbs Up Bow down James
Post #963088 27th Aug 2022 8:19pm
Co1
Enjoying the rebuild, it’s nice to vicariously carry out a restoration with you doing all the hard work!!!
Post #963098 27th Aug 2022 9:05pm
Dinnu
Indeed, will try to avoid doing the mistake and rush the final bits.
Indeed it was hard work, but hope that the hardest is over. Can’t believe that it is almost 4 years since it started Embarassed 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #963117 28th Aug 2022 8:51am
Dinnu
Forgot that I had also galvanized the slam panel braces. So some etch primer and painting later, they came out dull enough.. a bit glossier than I was aiming for.
A mystery I had been ‘worried’ about is solved. On old LandRovers, the seats bolt to nut plates that are riveted to the seat box. I have the middle seat, so was expecting 12 nut plates. But only had 8 nut plates. So why 4 missing? Well found out today. The rear of the middle seat, rear left of driver and rear right of passenger take a standard nut from bottom side. There is no 1/8” hole for the rivet to hold the nut plate for those holes Laughing
A little disappointment too Big Cry Found that the heat shielding fell off. The glue I used stuck really well to the paint but not to the foam. Wonder if the foam is well impregnated with oil from its previous smokey life Rolling with laughter
Post #963409 30th Aug 2022 7:54pm
Dinnu
Been a while since I got my hands dirty on my Land Rover Confused
But decided to resume with the swivel housings. First one dismantled... needs quite some cleaning, especially the swivelling part has some corrosion that needs a chisel to chip off. Guess will put them through some electrolysis. But the chroming on the ball is in good nick. Surprised to find 2 retaining rings for the ball seal.
Post #966664 4th Oct 2022 5:46pm
Dinnu
So started yesterday evening with the swivel housings in the electrolysis bath to dissolve the rust.
A good wire brush on the angle grinder, and then I thought why not give then a thin layer of zinc.
So now ready for painting.. but thats for another day.
Before and after zinc plating.
Post #966914 6th Oct 2022 6:24pm
Co1
Nice work Dinnu. Thumbs Up
Post #966965 7th Oct 2022 6:06am
Dinnu
So 'all' swivel related parts have been painted, only to realize, while cleaning the spray gun, that the brake pipe brackets that are fixed with the top swivel pin bolts were still attached to the brake calipers Surprised
So I will have to do those before I start assembly. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967187 9th Oct 2022 7:41pm
Dinnu
Left hand swivel assembly in progress.
The top swivel pin is only temporarily fitted. Already have a swivel preload of 3.5-4.5kg, but difficult to measure with the spring balance as it tends to oscillate. Top pin is without shims, and measured a gap of 0.80mm with feeler gauges. So that would be a good start for the shims I guess.
Post #967361 11th Oct 2022 5:53pm
