![]() | Home > My Defender > 1988 Shire Blue Landrover 90 Restoration |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3706 ![]() ![]() ![]() |
Looking incredibly clean! Nice work!
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3520 ![]() ![]() ![]() |
Thanks Col. It is many many hours of cleaning
![]() ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Turned my attention to the front calipers. I have actually set a target that by Christmas it should be able to move forward under its own power, so it also need to stop. Will be far from finished, but will be a milestone which I hope is reachable.
So I ended up splitting the calipers, this way the bores can be inspected and cleaned better. So some pictures in order: after 24hrs in the electrolysis bath dissolved most of the rust, but still needed a quick over with the wire brush. I have zinc plated them (no pic for that) and etch primed them. Have used the old pistons and the wipers to mask the bores. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Calipers ready, need to sort the short rigid pipe from caliper to flexi hose. The original ones are ok, but the nuts are a bit rusty. Checked the genuine ones.. but pricey for what they are
![]() ![]() ![]() Click image to enlarge On to the prop shafts. All good except one cross that showed a bit of play, so that is replaced. ![]() Click image to enlarge And painted a few more bits. ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Today I sat down behind the steering wheel of my 90 for the first time in more than 4 years. I was like a kid again on those kiddie rides 😂. Cannot describe my smile 😃
And ohhh my, the steering, the seating, and everything felt so different (and spacious) compared to the Puma ![]() ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2145 ![]() ![]() ![]() |
Enjoy it - you deserve a little bit of harmless fun after all your hard work.
![]() Did you make engine noises whilst turning the steering wheel from side to side? ![]() |
Hahaaha, yes, and shifting through the gears
![]() ![]() Although the gear stick is still not installed. But the imagination was there ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Fantastic! Well done you!!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Cheers James. Thank you.
Got the hard brake lines, from the G valve all the way to the rear slave cylinders, and the short ones on the front calipers done locally,. Collected today
![]() Made a quick tool to straighten the coiled uneven pipes, and worked really well. Now I need to build a bender, as the one I have creates a larger radius of curvature compared to the original lines. Then all that is needed is paint them green, just like how the originals were ![]() ![]() Click image to enlarge ![]() Click image to enlarge In case anyone wonders how the straightening tool works, the upper 2 bearings are fixed. Their ID is 10mm, perfect fit on M10 bolts. The lower bearing has an ID of 12mm, and use an M8 bolt. In between the M8 molt and the bearing race, I turned an M8 nut eccentrically, which threads on the bolt, and support the bearing. So by adjusting the spanner position on the M8 bolt, I can move the lower bearing upwards or downwards. So it was just a matter of trial and error adjusting the spanner back and forth until I was happy with the straightness of the lines. I kept 2 small pieces of wood to keep the tube centered on the bearings (I was keeping the lines down with my thumb). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Had a little knob moment...
When I had purchased the 90, replaced the gear knob (probably original was already falling off), and installed the gear knob that can be see on the left. I do not know the provenance of this knob, but have a feeling it came out of a Range Rover. ![]() Click image to enlarge Decided to go back to the original knob. ![]() Click image to enlarge Fitted the left inner mudguard... now waiting for delivery for some parts so the wheels can be fitted - but will stay on axle stands to avoid flat spots. ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Those galv inner wheel arches look very smart indeed! Nice to see the build coming together Dinnu, great work as always.
Thanks Col. The original inner mudguards were re galvanized. I only show the best part of the galvanizing
You won't get flat spots, you'll have it running about before then!!
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
