Home > Puma (Tdci) > New MY2011 door uderseal, who know more than me???
Page 4 of 8 <12345678>
dgardel
Italy
Thanks again Mate Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #69891 5th May 2011 10:07pm
bob neville
Started the fitting this afternoon - only one rear door so far due to other more pressing problems - leaking roof on the house that was supposed to have been repaired last month Big Cry
This is the route I took to fit the rear door seal.
1. Remove the door card - reason for this will become clear a bit later.
2. Drill out the pop rivets holding on the old bit of rubber strip - the original seal. Remove front rubber block - stuck on.
3. Fish out the bits of rivet now floating about in the bottom of the door (why the card was removed).
4. Enlarge exising holes where rivets were - an extra 1mm did the trick.
5. Paint holes and have a cup of tea.
6. Fit new seal using the five studs into the existing holes - they do just about line up.
7. Undo door stay so that you can get to the front door edge.
8. Drill holes in front and read door edge to take two new fixings and paint holes.
9. Clip last two fixings in, replace door stay and card.
Job done Thumbs Up
I didn't put waxoyl in the door this time as the pressure spray was playing up, I will do it when I do the other doors.
Only thing I need to check on a four door with the new seals is if the existing frame seal needs trimming at the rear for a proper fit, my door closes OK and there is no daylight showing so I will probably leave it as it is.
Bob
Post #70181 8th May 2011 6:36pm
BruceT
South Africa
Hazza wrote:
BruceT wrote:
Thank you for this. I have just ordered mine from Britpart. Looking forward to it. Smile
Britpart OR Britcar?
Harry
Appologies I meant Britcar. Embarassed
Bob thanks for the info.
Post #70182 8th May 2011 6:45pm
BruceT
South Africa
Just recieved the door seals. They look like great quality. I will also feed back to the forum should anyone be interested.
Post #72536 24th May 2011 4:58pm
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
new door cills
Please feedback with emphasis on the front doors and the need to drill new holes front and back sides. A piccy would be handy!
Thanks
El pepe flamenco JLS
'El Pepe Flamenco'
Post #72541 24th May 2011 5:42pm
BruceT
South Africa
OK will do.
Post #72543 24th May 2011 5:50pm
dgardel
Italy
BruceT wrote:
OK will do.
Waiting you. Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #72546 24th May 2011 6:08pm
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Hi Bruce,
WHat is the part number for your 110?
Does it include all 4 Seals?
Dave.
Post #72642 25th May 2011 4:38am
BruceT
South Africa
Hi Draymond.
Here you go.
1 x LR029307, LR029307 WEATHERSTRIP - DOOR - LOWER
1 x LR029308, LR029308 WEATHERSTRIP - DOOR - LOWER
2 x LR029309, LR029309 WEATHERSTRIP - DOOR - LOWER
The rear doors are not interchangable so you have to order as above.
Post #72648 25th May 2011 8:00am
Naks
Bruce, I take it these 2 are for the front doors? Did you check if the stealers have them and if so what the price is? --
Post #72660 25th May 2011 9:02am
BruceT
South Africa
Yes Naks.
Post #72662 25th May 2011 9:05am
BruceT
South Africa
Sorry naks. Didnt fully reply to you. I didnt bother checking with the local stealers.
I fitted the door seals today. I can say that it is a vast improvement to the original ones and has definatly made a diffenerce to road noise and from what I can see provides a far batter seal. It took me around an hour to change all the seals. I didnt bother taking off the door panels as I managed to just shake the doors to get the rivet pieces out. i also painted with primer.
I would highly recommend doing this.
Post #73348 29th May 2011 5:49pm
David128
Australia 2015 Defender 110 Puma 2.2 CSW Zermatt Silver
I have also noticed on one of the new special edition models that the bodywork that mates with the new seal looks galvanized and not painted. I want to check next time at the dealers. Anybody else seen this?
Post #74442 6th Jun 2011 1:38pm
bob neville
Word of warning if you fit these new door seals - don't get Waxoyl near them, they deform.
Got round to putting the Waxoyl into the rear doors yesterday and sprayed a bit to much in, with the heat etc. where the Waxoyl dripped out the door drains and contacted the rubber it has badly deformed one.
New seal on order tuesday Big Cry
Bob
Post #78068 27th Jun 2011 7:10pm
Zagato
Waxoyl deforms most rubber. The first time I used it, it bubbled up my ole mans tarmac drive Shocked ruined the door rubbers on my SAAB and made the tyres blister! I still can't see how it is able to do this if it just has white spirit in it, maybe something else was present - the blisters/bubbles did go back down again thank god before my father came home! Rolling Eyes
PS I have the old doors seals on mine, it came off the production line last August Confused
Post #78087 27th Jun 2011 8:20pm
