![]() | Home > Puma (Tdci) > New MY2011 door uderseal, who know more than me??? |
Thanks again Mate Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Started the fitting this afternoon - only one rear door so far due to other more pressing problems - leaking roof on the house that was supposed to have been repaired last month
![]() This is the route I took to fit the rear door seal. 1. Remove the door card - reason for this will become clear a bit later. 2. Drill out the pop rivets holding on the old bit of rubber strip - the original seal. Remove front rubber block - stuck on. 3. Fish out the bits of rivet now floating about in the bottom of the door (why the card was removed). 4. Enlarge exising holes where rivets were - an extra 1mm did the trick. 5. Paint holes and have a cup of tea. 6. Fit new seal using the five studs into the existing holes - they do just about line up. 7. Undo door stay so that you can get to the front door edge. 8. Drill holes in front and read door edge to take two new fixings and paint holes. 9. Clip last two fixings in, replace door stay and card. Job done ![]() I didn't put waxoyl in the door this time as the pressure spray was playing up, I will do it when I do the other doors. Only thing I need to check on a four door with the new seals is if the existing frame seal needs trimming at the rear for a proper fit, my door closes OK and there is no daylight showing so I will probably leave it as it is. Bob |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Just recieved the door seals. They look like great quality. I will also feed back to the forum should anyone be interested.
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Please feedback with emphasis on the front doors and the need to drill new holes front and back sides. A piccy would be handy!
Thanks El pepe flamenco JLS 'El Pepe Flamenco' |
OK will do.
Waiting you. ![]() ![]() ![]() ![]() IID Pro MV License |
draymond Member Since: 07 Apr 2009 Location: Sydney Posts: 49 ![]() ![]() ![]() |
Hi Bruce, WHat is the part number for your 110? Does it include all 4 Seals? Dave. |
Hi Draymond.
Here you go. 1 x LR029307, LR029307 WEATHERSTRIP - DOOR - LOWER 1 x LR029308, LR029308 WEATHERSTRIP - DOOR - LOWER 2 x LR029309, LR029309 WEATHERSTRIP - DOOR - LOWER The rear doors are not interchangable so you have to order as above. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
Bruce, I take it these 2 are for the front doors? Did you check if the stealers have them and if so what the price is? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Yes Naks. |
Sorry naks. Didnt fully reply to you. I didnt bother checking with the local stealers.
I fitted the door seals today. I can say that it is a vast improvement to the original ones and has definatly made a diffenerce to road noise and from what I can see provides a far batter seal. It took me around an hour to change all the seals. I didnt bother taking off the door panels as I managed to just shake the doors to get the rivet pieces out. i also painted with primer. I would highly recommend doing this. |
David128 Member Since: 31 Jan 2010 Location: Melbourne Posts: 30 ![]() ![]() ![]() |
I have also noticed on one of the new special edition models that the bodywork that mates with the new seal looks galvanized and not painted. I want to check next time at the dealers. Anybody else seen this?
Word of warning if you fit these new door seals - don't get Waxoyl near them, they deform.
Got round to putting the Waxoyl into the rear doors yesterday and sprayed a bit to much in, with the heat etc. where the Waxoyl dripped out the door drains and contacted the rubber it has badly deformed one. New seal on order tuesday ![]() Bob |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5025 ![]() ![]() |
Waxoyl deforms most rubber. The first time I used it, it bubbled up my ole mans tarmac drive
![]() ![]() PS I have the old doors seals on mine, it came off the production line last August ![]() |
