Home > Puma (Tdci) > New MY2011 door uderseal, who know more than me???
Page 3 of 8 <12345678>
bob neville
Re: 'improved' door seals
jlerra wrote:
Any news anyone on the fitting of front 'improved' door seals (LRO 29309)?
Would welcome news of fitment/mod required.
El pepe flamenco
I will let you know when mine turn up Thumbs Up
I can tell you that there are a couple of fixings into the side of the door that look like they will need drilling for.
I am not sure if all the fixings are supplied as they did not show on microcat so it could be a while before I get them fitted.
Bob
Post #69612 4th May 2011 8:19am
mse
I would expect them not to be...what do they look like?
Just looked on my microcat (admitedly its last update was Sep 2010) and it shows the same rivets as used in the old style seals...what version are you using? Mike
Post #69623 4th May 2011 11:07am
bob neville
Mike
We had a look on the latest version at the dealers and it only shows the old style fixings as well. The new seals are shown OK but only old type fixings.
There are at least two side fixings which are not applicable to the old style seal and these are not shown so may be included - the parts guy had a good look at the ones fitted to the new defender and said this may be the case - I will find out when they arrive !
Bob
Post #69628 4th May 2011 12:17pm
RED-DOT
They will stop the sheep and dogs escaping?? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #69643 4th May 2011 2:06pm
bob neville
Should do and stop the mice getting in Thumbs Up
Bob
Post #69644 4th May 2011 2:08pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
I've just contacted Ripon LR, they can order in the new seals for £15+vat, will let you know how i get on!
Harry 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #69647 4th May 2011 2:47pm
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
'new' door seals
Keep us in the picture when you get them/fit them, re: fitting.
El pepe flamenco JLS
'El Pepe Flamenco'
Post #69665 4th May 2011 6:10pm
bob neville
Just picked my new seals up - £61.20 for the four and looks like money well spent Thumbs Up
Fixing is by press in studs, all supplied, so looks like a job of drill the holes, paint the bare metal and fit.
That is this weekend sorted out Laughing
Bob
Post #69777 5th May 2011 1:28pm
BruceT
South Africa
Thank you for this. I have just ordered mine from Britpart. Looking forward to it. Smile
Post #69809 5th May 2011 5:05pm
mse
Bob
And spray in some waxoyl Thumbs Up Mike
Post #69818 5th May 2011 5:45pm
Hazza
Britpart OR Britcar?
Post #69820 5th May 2011 5:50pm
dgardel
Italy
Bob
Could you post photos???? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #69826 5th May 2011 5:58pm
bob neville
Not the best thing to take a picture of !
The small black flaps you can see also have black studs in for side fixing. One front and one back shown.
Bob
Post #69854 5th May 2011 8:29pm
dgardel
Italy
Thank you Bob,
the white plastic fixing (on the horizontal side) have the same distance of the old ones? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #69872 5th May 2011 9:11pm
bob neville
I did a quick check earlier and they did appear to be the same spacing - as far as LR tolerances go !
It looks like it is just a job of drilling holes in each door for the front and rear side fixings - plus waxoyl Mike Thumbs Up
Bob
Post #69874 5th May 2011 9:21pm
