Home > My Defender > My 110 MILLIE.
Page 47 of 67 <123 ... 464748 ... 656667>
Procta
Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #878373 14th Jan 2021 6:04am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Good to hear Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #878478 14th Jan 2021 3:51pm
L110CDL
Yesterday i had a call from John regarding the pump as they were setting up the equipment to test a few pumps and what i wanted to do if they could not find anything wrong with my pump, i replied back by saying " if you can't find nothing wrong with the pump, then can you put it back to standard ( i had the pump upgraded ) as it's no good to me as it is " okay he said and he will get back in touch next week to let me know the outcome of the pump Neutral Clayton.
Keeper.
Post #878709 15th Jan 2021 9:04pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Thumbs Up
Post #878716 15th Jan 2021 9:29pm
L110CDL
I had a call from John regarding the injection pump, he said that there was nothing wrong with it Rolling Eyes and it was ready to be picked up. The way the weather was today i was lucky enough to go and pick my pump up on the way home from the prep work that we were doing up at our store. The pump is back to standard now and will be put on a shelf in my shed to be a spare when needed, the only bit of good news after all this, is that they gave me a £46 refund Neutral
This is not the outcome i wanted, so i will have to do some more homework now Rolling Eyes Clayton.
Keeper.
Post #879794 20th Jan 2021 7:43pm
donmacn
Hey Clayton,
Sorry to hear you're puzzling with this. I sent my pump down to Electro Diesel and spoke to John a few times. When they did the pre-test he said mine was 15% below standard, then they tweaked it. I've been very happy with it.
But I was puzzling over your symptoms. This is probably a really basic suggestion, which you or your indy will already have considered - but it's not mentioned. Did you change or check the vacuum advance pipe - the one that runs from the turbo to the fuel pump?
When I first investigated mine, I found a couple of small-ish but significant holes where it had rubbed through against the fuel pipes. If there are small leaks here, it would stop the pump diaphragm giving enough fuel advance. At low revs, this might be more important and reduce your torque?? A few ifs and maybes in there... and like I say it's maybe too obvious a suggestion.
EDIT: Lift pump? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #879826 20th Jan 2021 10:11pm
L110CDL
Hi Don
Yes we did put a new Vacuum pipe on to make sure Thumbs Up
This is where the puzzle gets more interesting, so when the tweaked pump came off and my spare went on, the difference between them was chalk n cheese Confused
Your last paragraph sums it up perfect which seems to be happening to the tweaked pump, but putting my spare pump on with no other changes is what is so strange, it was like it was the tweaked one, but it's a totally standard pump Shocked
I still think that there is something wrong with the pump that no one can find out what it is Rolling Eyes Clayton.
Keeper.
Post #880210 22nd Jan 2021 9:02pm
Have you tried PF Jones? I believe they are diesel specialists that could maybe investigate? Although, I don’t know if that is what they will undertake but maybe worth a look?
That’s where my VCV came from, they do lots of diesel parts and stuff and probably repairs. KEEP CALM AND Drill ON
Post #880359 23rd Jan 2021 5:50pm
Procta
I think its time for a second opinion, see if there is another diesel specialist and ask them to see if they can test it Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #880705 25th Jan 2021 5:59am
L110CDL
I will do in time Procta Thumbs Up Clayton.
Keeper.
Post #880885 25th Jan 2021 9:42pm
L110CDL
I did look them up and they only do the puma engine pumps as they do Ford transit pumps as well Wink
I did come across Dieselbob but i don't know anything about them Neutral Clayton.
Keeper.
Post #880886 25th Jan 2021 9:44pm
L110CDL
Millie went in for another one of her 6,000 mile service on the Saturday just gone, all went okay and i got my indy to do a few other jobs that needed doing and she's all good so far Very Happy Clayton.
Keeper.
Post #888549 1st Mar 2021 9:01pm
Procta
Post #888749 3rd Mar 2021 5:34am
L110CDL
I got 2 new BFG's fitted to the front of Millie today Very Happy Clayton.
Keeper.
Post #888887 3rd Mar 2021 8:29pm
Badger110
They're possibly next on my list, what size do you have?
Post #888900 3rd Mar 2021 9:35pm
