Home > Maintenance & Modifications > Replacement headlight harness - Highly recommended
Page 7 of 11 <123 ... 678 91011>
jimbob7
They do two versions (didn't notice the ceramic ones before??), one with ceramic connections and one with standard plastic connections,whats the advantage/disadvantage between the plastic and ceramic connections,as they are the same price?
https://shop.landreiziger.nl/catalog/product_compare/index/ Pov.spec,ftw. 2006, 110,TD5.
Post #327929 2nd May 2014 9:44pm
ericvv
I think the one with ceramic headlamp plug is very new on their site. I surely would have noticed it if it had been there before. The price is the same as the version with the AMP (what does that mean?) headlamp plugs, so seems an improvement at no extra cost.
I never have seen ceramic headlamp plugs, so wonder why they did this.
Your comparison link does not work for me, so here are the respective direct links to both versions.
Eric
Ceramic
https://shop.landreiziger.nl/modificatie/m...toren.html
AMP
https://shop.landreiziger.nl/modificatie/m...elais.html You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #327934 2nd May 2014 9:55pm
jimbob7
I can only think its a heat thing,maybe more reliable in hotter countries,but how would ceramic cope with vibration,dunno??
I think AMP is a quality brand of electrical connectors. Pov.spec,ftw. 2006, 110,TD5.
Post #327939 2nd May 2014 10:22pm
munch90
ceramic plugs are better for heat , I have seen the plastic ones melt but it's only when the metal tags inside are loose , people move the plug side to side to get off the bulb which spreads the tags open leaving them loose on the bulb and then they get hot
Post #327940 2nd May 2014 10:27pm
jimbob7
Emailed them yesterday to ask why.It's a heat thing,although they haven't had any problems, nearly everybody uprates their bulbs, plus a large number of customers fit 100w bulbs,so they jumping the gun before they have any issues,ceramic ones are also cheaper to make due to different or less fittings on the ceramic connectors (less labour intensive,thats what they said Question ) so it looks like plastic fittings may go up in price. Pov.spec,ftw. 2006, 110,TD5.
Post #328015 3rd May 2014 1:48pm
ericvv
Post #328029 3rd May 2014 2:34pm
g-mack
Post #328031 3rd May 2014 2:35pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
You can buy all the bits for less than that and do your own Thumbs Up 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #328076 3rd May 2014 5:34pm
kmac
munch90 wrote:
use the original earth for relays and new heavy earth for lights
New "heavy" earth on both relay and lights. Finally got round to finishing this mini project off.
Unless of course I can get hold of some ceramic H4 connectors......
Post #328121 3rd May 2014 8:25pm
jimbob7
/\/\/\Eblag £5 fer 2 Pov.spec,ftw. 2006, 110,TD5.
Post #328134 3rd May 2014 9:11pm
kmac
yeah thanks jimbo - had a quick look there.
might wait till the plastic ones melt first
Post #328162 3rd May 2014 10:14pm
munch90
trouble is the ceramic ones all come pre wired with a short wire so you have to have extra joints .
I prefer one length of wire
the plastic ones are ok ( on standard bulbs ) as long as they are tight if you change a bulb just tighten the tags when you refit
Post #328165 3rd May 2014 10:42pm
kmac
Does electricity not like joints? Should be okay if soldered no?
Even I'm partial to a joint
Post #328172 3rd May 2014 11:10pm
munch90
one wire looks neater , even though you cant see it
joints corrode , yes you can heat shrink and seal
joints put a stiff bit in the wire , make sure wires are long enough
just me being fussy really !!!
Post #328211 4th May 2014 8:04am
jimbob7
The company said ceramic wiring looms are cheaper/easier to produce so I assume they would utilise the pre-wired ceramic connector and just need to make one connection at the relay. Pov.spec,ftw. 2006, 110,TD5.
Post #328229 4th May 2014 9:53am
