Home > Maintenance & Modifications > Replacement headlight harness - Highly recommended
Page 2 of 11 <123 ... 91011>
Merlin
Any idea why there is a picture of the light switch in the description? I couldn't get Google to translate the page.
Merlin
Post #299949 18th Jan 2014 3:53pm
mk1collector
Myself having a keen interest in mk1 golfs, I know the headlights have the same candle like output as defenders and there are quite a few upgraded looms for sale readily available on the evil bay and I presume with a little bit of wire lengthening for the battery terminals that these will be fine on defenders too. These could be a cheaper way of doing this job.
Ebay no: eBay Item No. 301072992245 for example
Any electricary experts with any thought?
Ray
Post #299963 18th Jan 2014 4:48pm
ZeDefender
It amazed me that I couldn't find an equivalent in the UK or Germany - I doubt it has a patent Whistle Tell someone you love them today because life is short.
Post #299964 18th Jan 2014 5:06pm
ibexman
Devon 4x4 do an arb one but it's loads££
Post #299969 18th Jan 2014 5:20pm
mk1collector
I've just looked at the one on Devon 4x4 and as I posted earlier I think the mk1 golf versions (with the battery terminal wires extended) should work just the same and at a third of the price.
Post #299971 18th Jan 2014 5:29pm
munch90
when I done mine I used 4 relays ,2 each side fitted right behind headlight to keep length of wires to minimum and neater has its all behind headlight out of site ( apart from heavy feed wires to relays ).
also I used the offside and nearside headlight wiring to control the relays .
if your only using wires from one side to control both headlights through the relays then if that one side plays up you lose both headlights .
chances of it happening pretty slim I suppose . but I choose to use both sides
Post #299981 18th Jan 2014 5:53pm
ZeDefender
It looks the job but perhaps not as tough - the dutch one has cable sheaths and the connectors look better quality. Mind you, it's 10 quid cheaper Thumbs Up Tell someone you love them today because life is short.
Post #299992 18th Jan 2014 6:25pm
Mo Murphy
Merlin
Merlin, they do 2 kits, one with a new switch, one without.
I recommend this kit too, it's nicely made and like the other chaps here I couldn't find anyone selling a suitable kit in the UK.
50 Shades of Pennine Grey
Post #300178 19th Jan 2014 8:27am
ZeDefender
Yes - the kit advertised on the newer webpage for 52,50 Euros includes a new switch (I hadn't noticed). When I bought it, it was just the harness Thumbs Up Tell someone you love them today because life is short.
Post #300185 19th Jan 2014 9:11am
ZeDefender
One last note - I just extended the earth cable to reach a convenient point on the engine block. Tapping onto the HeatShock earth on the bodywork was bad practice (I know Rolling Eyes ) and causing a poor earth Thumbs Up Tell someone you love them today because life is short.
Post #300804 21st Jan 2014 10:16am
x-isle
I'm looking at doing this and whilst it's pretty simple to knock this loom up, for the money it costs from our Dutch friends, it's hardly worth it.
The one concern I have with this kit is that fuse seems to be be close to the relay box rather than the battery terminal, is this correct or am I looking at it wrong?
If so, I think I'd rather connect the + into a fuse near the battery than have a live un-fused cable running into the engine bay? Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #303089 29th Jan 2014 1:01pm
ZeDefender
Yes - there are two 30A fuses in waterproof enclosures, one for each light, next to the relays. I also thought about moving/adding to them but since they are easy to get to in the engine compartment and I'm both optimistic and lazy, I didn't Whistle
Have fun,
Matt Tell someone you love them today because life is short.
Post #303100 29th Jan 2014 1:41pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The harness from NL is supposed to be connected to the rear of the alternator. This is virtually impossible on the Puma without major dismantling, hence the need to go back to the battery. If connected to the alternator then the fuses are very close to the connection. On mine I put a 40amp in-line fuse in the mains feed to the relays and also ran the lead on its own . On pre-Puma models you can connect to the alternator easily.
As long as the +tve extension cannot earth, due to sharp bends or rubbing away insulation! there should be no problem. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #303120 29th Jan 2014 3:24pm
ZeDefender
You know it makes sense Thumbs Up Tell someone you love them today because life is short.
Post #303148 29th Jan 2014 5:22pm
ericvv
I ordered a harness with light switch from Landreiziger.... Now they ask me which light switch I need, the one with the white connector or with the brown connector.....
Anybody knows which one I should select for a Puma 2.4 model year 2009?
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #303379 30th Jan 2014 12:57pm
