Home > Technical > THE webasto Thread |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
I'll take a photo of mine later showing the one way valve from the expansion tank 2007 TD5 90 Hard Top
28th Nov 2012 7:48am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
What's the theory behind the expansion tank one-way valve then chaps? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
28th Nov 2012 11:34am |
OK - but presumably it affects the designed operation of the header tank which should have free flow both ways through that pipe? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
28th Nov 2012 12:01pm |
I Could be way off mark but I think the small hose takes the expansion water from the system which is then fed back in through the larger hose at the bottom of the tank.
Click image to enlarge 2007 TD5 90 Hard Top |
28th Nov 2012 12:17pm |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 |
Not sure about this, but I know when I put a Webasto in my TD5, until I put a one way valve on the expansion tank the pump on the Webasto would draw air into the coolant system causing no water to pump around and the Webasto to overheat and shutdown. |
28th Nov 2012 1:25pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8065 |
i had one of these on my td5 header but not on the puma. why do you need it? Cheers
28th Nov 2012 1:27pm |
Click image to enlarge ITEM N° 3 Without check-valve, the expansion box coolant level go up (3 - 4 cm) when the engine is warmed up. With the valve the "problem" was gone. On the original TD5 Land Rover Webasto KIT, the installation of the valve is MANDATORY! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 28th Nov 2012 2:23pm. Edited 2 times in total |
28th Nov 2012 1:33pm |
Thanks Daniele
Do you have the whole PDF for Td5 installation? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
28th Nov 2012 1:35pm |
Sorry for my last post, i hadnt seen the next page after BPMans post with all the pics etc of it.
ON my td5 i fitted one (a one way valve on the expansion tank). On the puma i dont have one fitted and have no problems with it to date. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
28th Nov 2012 1:45pm |
Translation of German above:
28th Nov 2012 2:15pm |
English (traslated from the french version) https://www.defender2.net/gallery/albums/u...TD5_EN.pdf French https://www.defender2.net/gallery/albums/u...TD5_FR.pdf German https://www.defender2.net/gallery/albums/u...er_TD5.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
28th Nov 2012 2:33pm |
Thanks 1988 90 Td5 NAS soft top
2015 D90 XS SW |
28th Nov 2012 2:37pm |
My FBH has stopped working
Took the supply fuel pipe off the heater end and once the fuel pump starts a couple squirts come out and then nothing although the fuel pump can be heard clicking. Does this sound like fuel starvation and is there a fuel filter built in to the system ? Have checked fuses etc but all ok. FBH stars running on demand but then shuts down after 3 minutes ? 2007 TD5 90 Hard Top |
31st Dec 2012 7:34pm |
could be the fuel filter in the pump is blocked... you've been using non-BP fuel ?
3rd Jan 2013 7:06am |
