Home > Technical > THE webasto Thread |
I'm doing it JSTs way so took a bit of force to get the duct out on Sunday. But minesa going in backward to JSTs so I'm making a ss bracket this week. Should be the hardest bit done. Then connect it all up and buy a T71....that'll blow the budget.
110's in for a new TB next week |
12th Nov 2012 2:14pm |
Marcus - T71 or a T91 ?
12th Nov 2012 7:42pm |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 |
For anyone following on, this has turned out to be the perfect solution and much better than the standard control board. A basic ability at soldering is required, but nothing too taxing. Once installed it is switched by a simple 12V supply and has all the usual safety cut-outs. It also has a number of LEDs so you can see what it is doing and an onboard buzzer which allows for fault code analysis. Arrived within 4 days of ordering. Thanks dgardel works a treat |
16th Nov 2012 4:07pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1786 |
After sitting for a couple of hours each way at Portsmouth & Caen last week, I decided to get my 4rse in gear and start to fit my Eberspacher D3 today.
Went the DGardel route and cut an access panel in the rear floor, pulled the sender unit out and made a dip tube from some 5mm Kunifer tube, drilled a 8mm bolt lengthways and silver soldered it approx 320mm up the pipe, giving me a bulkhead fitting I could fit seals to and bolt through the sender unit. I put a single flare on the outlet end of the pipe, where the rubber fuel line pushes over. I cut a pieice of stainless plate and siliconed it over the hole so it doestn't show through the mat. I fitted the unit under the second row of seats, but haven't finished running the wiring yet. Temporarily rigged up a supply from the additional fuse box, and it fired up second attempt - TOASTIE! Keith |
18th Nov 2012 8:12pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Does anyone have a part number/source for the one-way valve?
Looking at fitting a D3-sourced ThemoTop to my Td5 engined 90 - is the one way valve necessary on Td5? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
27th Nov 2012 6:21pm |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
ask dgardel - not sure on the TD5 but mine (Puma) is fine without |
27th Nov 2012 6:30pm |
Martin, there are 2 one-way valves, one on the expansion tank one in line with the heater pipes the heater valve is a 12780A, this is the 4 port one way value HTH |
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
27th Nov 2012 6:50pm |
No, but it makes it more effective. |
Dgardel, is that the one-way for the expansion tank?
27th Nov 2012 6:51pm |
Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License Last edited by dgardel on 27th Nov 2012 6:56pm. Edited 1 time in total |
27th Nov 2012 6:54pm |
yes Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
27th Nov 2012 6:55pm |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 |
Hi. Ive just bought a Top C and this part came with it. Where does it go in the system? I'm a bit confused!
Cheers Cetane
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
27th Nov 2012 8:35pm |
cetane
the valve goes on the small pipe out of the expansion tank |
28th Nov 2012 7:22am |
