Home > Technical > THE webasto Thread
Page 15 of 16 <123 ... 141516>
Martin
Site Admin
TJH1985 wrote:
Martin - What software do you need to flash them?
It's the Webasto Thermo Test software but I'm not 100% happy now so I'll hold off on the how-to Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #753595 24th Jan 2019 12:01pm
Martin
Site Admin
grafty99 wrote:
Martin wrote:
There's an aftermarket 12V -> WBUS converter available on eBay for about £35 (cheaper than the Oval timer).
Could you post a link please Martin? Can't find it via the keywords I've tried Thumbs Up
https://www.ebay.co.uk/itm/Analog-to-W-bus...2776404068
I've not used one myself but guys on DISCO3 have.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #753601 24th Jan 2019 12:13pm
grafty99
Ideal thanks Martin Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #753604 24th Jan 2019 12:17pm
TJH1985
I’ve never noticed the option, although I’ve never been looking for it to be honest. Thumbs Up
Which version do you use?
Post #753607 24th Jan 2019 12:26pm
isacs
so I've fitted a cab heater which is just connected to my battery, question is do i need to fit an additional leisure battery?
Greg
Post #754543 28th Jan 2019 6:17pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Depends on how long you plan to run it for? If you're thinking of running it constantly during the night as the outside temps are -20 outside, then i'd probably consider it.
If it's a back up to the standard heater and you're not going to run it for long periods ( think 5-6 hours ) without the engine running, then i reckon you'll be just fine Thumbs Up
Post #754555 28th Jan 2019 7:01pm
isacs
It’s when I leave it in the feilds, so only for 30mins to 2hrs. I might try it for long sessions on the drive. So if it won’t fire the engine after at least I’m not stranded
Post #754606 28th Jan 2019 8:30pm
Badger110
You should be fine, but a test is a good idea Thumbs Up
The main draw is on fire up, once the unit hits temp ( about a minute ) then the power draw drops drastically.
Turning it on for a few minutes whilst the engine is running wouldn’t be a bad idea
Post #754705 29th Jan 2019 8:14am
TJH1985
It was an ideal Oc outside this morning so I thought it would be an excellent time to catch some data around coolant temperature with the Webasto only - Here is a 30 minute warm up with the Defender set to max fans and hot first thing this morning.
Thermotop C wired in series just before the heater Matrix, so naturally, the heater output seems to be good enough to defrost etc. within minutes.
Post #755414 1st Feb 2019 9:28am
walfy
Trying to sort out a remote for my Airtop ST2000, I spoke to several people and even a Webasto technitian. They all said that the T91 kit would work. I can confirm that it doesn't, I've tried all variations so I've pulled the T91 kit out and now sourcing another option.
I was under the impression that the Thermocall was only for newer models? Has anyone found a cheaper version of remote control? 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #755506 1st Feb 2019 5:33pm
Martin
Site Admin
How is your AirTop normally switched on?
Which Telestart kit do you have?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #755514 1st Feb 2019 6:19pm
walfy
Martin, I only have the rheostat to turn it on. Which means trudging down the garden to turn it on. Would rather just sit in bed and turn it on.
Don't have a telestart kit, The T91 is an RF unit from what I gather. Which is now surplus to requirements so will appear for sale very soon 110 D250 SE HT
110 USW SOLD
Post #755517 1st Feb 2019 6:23pm
Martin
Site Admin
T91 is Telestart Confused
Got a photo of your T91 kit?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #755518 1st Feb 2019 6:28pm
walfy
Ah, my mistake. I'll get a photo shortly 110 D250 SE HT
110 USW SOLD
Post #755519 1st Feb 2019 6:32pm
walfy
Pics as promised
Label on control unit
Remote
General Box Pic
Box label
 110 D250 SE HT
110 USW SOLD
Post #755526 1st Feb 2019 6:57pm
