Home > Technical > THE webasto Thread
Page 10 of 16 <123 ... 91011 ... 141516>
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
I'll take a photo of mine later showing the one way valve from the expansion tank 2007 TD5 90 Hard Top
Post #189154 28th Nov 2012 7:48am
Martin
Site Admin
What's the theory behind the expansion tank one-way valve then chaps?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #189191 28th Nov 2012 11:34am
Landlord
Think it to do with the height of the Webasto in relation to the expansion tank. As the Webasto is installed quite high on the TD5 I presume there could be a chance of air traveling back down the top hose causing an air lock. 2007 TD5 90 Hard Top
Post #189196 28th Nov 2012 11:59am
Martin
Site Admin
OK - but presumably it affects the designed operation of the header tank which should have free flow both ways through that pipe?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #189197 28th Nov 2012 12:01pm
Landlord
I Could be way off mark but I think the small hose takes the expansion water from the system which is then fed back in through the larger hose at the bottom of the tank.
Post #189201 28th Nov 2012 12:17pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Not sure about this, but I know when I put a Webasto in my TD5, until I put a one way valve on the expansion tank the pump on the Webasto would draw air into the coolant system causing no water to pump around and the Webasto to overheat and shutdown.
Post #189212 28th Nov 2012 1:25pm
jst
i had one of these on my td5 header but not on the puma. why do you need it? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #189213 28th Nov 2012 1:27pm
dgardel
Italy
ITEM N° 3
Without check-valve, the expansion box coolant level go up (3 - 4 cm) when the engine is warmed up. With the valve the "problem" was gone.
On the original TD5 Land Rover Webasto KIT, the installation of the valve is MANDATORY!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #189214 28th Nov 2012 1:33pm
Martin
Site Admin
Thanks Daniele Bow down
Do you have the whole PDF for Td5 installation?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #189215 28th Nov 2012 1:35pm
jst
Sorry for my last post, i hadnt seen the next page after BPMans post with all the pics etc of it.
ON my td5 i fitted one (a one way valve on the expansion tank).
On the puma i dont have one fitted and have no problems with it to date. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #189218 28th Nov 2012 1:45pm
Martin
Site Admin
Translation of German above:
Quote:
CAUTION!
When installing the non-return valve respect the forward direction!
  • Loosen the vehicle pipe (19/1) at the hose (19/4) connecting to the expansion tank.
  • Insert the check valve (19/3) in the hose (19/4) (the forward direction is from the engine to expansion tank) and secure with hose clamp
  • Attach the vehicle pipe (19/1) using a piece of tubing (19/2) and 2 hose clamps
2015 D90 XS SW
Post #189224 28th Nov 2012 2:15pm
dgardel
Italy
English (traslated from the french version)
https://www.defender2.net/gallery/albums/u...TD5_EN.pdf
French
https://www.defender2.net/gallery/albums/u...TD5_FR.pdf
German
https://www.defender2.net/gallery/albums/u...er_TD5.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #189225 28th Nov 2012 2:33pm
Martin
Site Admin
Thanks Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #189227 28th Nov 2012 2:37pm
Landlord
My FBH has stopped working Big Cry
Took the supply fuel pipe off the heater end and once the fuel pump starts a couple squirts come out and then nothing although the fuel pump can be heard clicking. Does this sound like fuel starvation and is there a fuel filter built in to the system ?
Have checked fuses etc but all ok. FBH stars running on demand but then shuts down after 3 minutes ? 2007 TD5 90 Hard Top
Post #197952 31st Dec 2012 7:34pm
could be the fuel filter in the pump is blocked... you've been using non-BP fuel ?
Post #198553 3rd Jan 2013 7:06am
