![]() | Home > Technical > Disaster - YEOVIL LR save the day and get it fixed ! |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2660 ![]() ![]() ![]() |
Nice one Bob
Now go and win the challenge - no pressure mate ![]() Best wishes Mark |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2720 ![]() ![]() |
Am I missing something here? I was under the impression that the transfer box as used on the current day Tdci Defenders is the same basic unit that Land Rover have been using since the early 1980s? Was it a part in the actual transfer box that failed, or the output shaft of the main gearbox...which interfaces through splines with the input gear inside the transfer box?
Assuming it is the transfer box, then presumably something has changed with the design of the LT230, as it's just about the strongest part of the drive train in a Defender. Early (up to 1997 or so) boxes had problems with accelerated wear between the input gear and the output shaft of the main box, but this was fixed in later models with a cross-drilled input gear. And why the secrecy? I don't understand what could have failed that wouldn't be suitable for public broadcast. |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
This happened to mine. It had only done about 17k at the time and had never been off road... |
sorry mate, can't tell you ![]() if you re-read the post, the theory is the mechanics have stayed the same but the torque output has increased over the years and the original design is simply not upto the job |
What about all the LT230s behind big yank V8s and large lumpy diesels?
Not saying that scenario isn't the case, it's just kinda hard to figure out what's failed when we can't be told what's failed... |
I know - I hate it when people won't tell you why they can't tell you because if they did, it would be telling ![]()
I was also puzzled by the "secrecy" - is that all it is? If you say you can't tell me, I'll throw my slipper at you ![]() But shout it at them in German because life is also terrifying and confusing... |
I've heard the same theory on more than once occasion. I too asked about the V8s, but apparently they don't have as much torque low down like the pumas. Having said that there's plenty of pumas that work very hard for a living, yet this issue seems quite rare. |
Okay, so case in point would be the Mazda SL35Ti. Produces 377Nm of torque, 17Nm more than the Tdci, and fitted to thousands of Range Rovers in the 80s (and subsequently many Defenders) without issues. Quite a few LT77 and LT85 main boxes have succumbed to them from what I've heard, but never heard of a transfer box giving up.
Assuming no tuning... it's relatively easy to get another 50Nm+ out of a Puma (or more with uprated intercooler etc.) Maybe there's a good reason why LR limit these things ![]() But shout it at them in German because life is also terrifying and confusing... |
Of course, quite agreed. I'm sure with some tweaking of the pump the Mazda engine would give extra power as well.
But my point is that LT230s have been putting up with engines that are more powerful, more torquey and a lot less refined than the current unit for over 20 years. So something must have changed for them to be failing. |
a) I hope you're right; and b) I hope mine or yours isn't one of them... p.s. LR Deutschland still haven't replied about the manufacturing plants - wonder how they'll squirm out of answering ![]() But shout it at them in German because life is also terrifying and confusing... |
Probably by just not answering! Hopefully my transfer boxes should be OK, I'm only running Tdis and soon to be the aforementioned Mazda ![]() |
Is it ? Ashcroft have just released one specific to the 2.4 engined puma ![]() I posted the details about the part that failed, the rest of the conversation between the dealer and myself is between them and I. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
well, that's a cliff-hanger comment! ![]() ![]() ![]() ![]() |
