![]() | Home > Technical > Disaster - YEOVIL LR save the day and get it fixed ! |
Hi Mark Didn't win but didn't lose either ![]() Lost about 30% of the entrants on day one, one set of marshals slid totally out of control into a river and had to be towed out by a tractor and LRE team. I ended up as driver and winchman, not sure how that happened ![]() We finished both days and had a great time. I will do a full post when I have recovered. Bob PS even had snow this morning ![]() ![]() 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Got my reply from LR Germany
![]() They claim the MY11 gearbox (MT82) is made by Getrag in Germany (Köln) and that the transfer box is made in England (but couldn't be more specific). Quite a surprise, considering the rumours ![]() (will post this under "Puma" as well) Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2734 ![]() ![]() |
They may have changed some internal components, but even looking on Microcat they've got the same input gear setup, same intermediate gear setup etc. It's the same box, in the same way that an LT230 from a Td5 is the same as one from a 1983 110. So the splines on the output shaft of the gearbox wore away to nothing, the point I'm making is that this is a known issue with much earlier LT230s that has been considered 'fixed' since the late 300Tdi era with the introduction of the cross-drilled input gear. Of course a Tdci would have had this gear from new so there must have been some other fault to cause the wear. Perhaps a bad batch of gearbox output shafts that hadn't been hardened properly? Or a lubrication issue with the oil itself, rather than supply of oil to the splines. You're within your right to withhold the reason for the failure (though I'm not sure why - I doubt it's something you're at fault for so you can only be protecting Land Rover) but there must be something else at play here the way I see it ![]() |
Retro
Very interesting point you have made there ![]() To be honest, I don't know one end of a gearbox/transfer box from the other, that is why I always let somebody who does know them work on them for me. I explained the issue to somebody who works for me today (he knows LR's inside out) and he said exactly the same as you, problem fixed circa 300tdi, cross drilling etc and I would trust him (and yourself) that this is in fact true. When he heard what I described his opinion was that the the Puma shafts are not cross drilled and hence the problem. I never asked (or was told) if the shaft is or is not cross drilled so can't tell you the exact reason for failure, I was just glad they fixed the vehicle so quickly. One thing I did see was the smaller end of the shaft with the large splines on appeared to have plenty of lubrication, the failing end was dry (could have been wiped off) but the remaining splines looked as though they were rusty ? I am sure somebody like Ashcroft can tell you if the shafts are cross drilled, if they are then the problem lives elsewhere. There is nothing else 'at play', I am as intrigued as you are as to why the shaft failed. The true reason behind the failure was not disclosed. My opinion is that it is something that has been changed to mate the new gearbox to the existing transfer box and that something is not correct. All I can say, is since the dealer did the work the whole drive train on my Puma has been transformed. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
Bob, So where are the pics then?
Tuesday I hope - provided my limbs have started working again
![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Thanks for getting back to me. I would be very surprised if the Puma input gear was not cross-drilled...but Land Rover have done stranger things! I hope we're talking about the same part here. I am referring to the output shaft of the main gearbox, which extends into the input gear of the transfer gearbox. It is hidden behind the PTO plate on the left of the handbrake drum as you look at the back of the transfer box from under the vehicle. See here for an example of the play that can develop. You are looking at the output shaft of the main gearbox meshing (badly - due to wear) with the input gear of the transfer box. Note the shaft moving relative to the gear that surrounds it. This play was caused by lack of lubrication to the drive splines on the inside of the gear where the shaft goes in. Later models of input gear had holes drilled through to allow EP90 into the splines and provide the necessary lubrication: ![]() Is this the part you are referring to? The only other parts of the transfer box with splines are the two output shafts and the relevant prop shaft flanges that go onto them. There is no cross-drilling of these, but they run immersed in the oil. These are not known to wear particularly, and I have not personally heard of one failing. What makes me want to clarify is your mention of the 'smaller end of the shaft'. The output shaft of a main gearbox should look like this (shown with the PTO plate and input gear removed from the transfer box): ![]() Does that make any sense to you? |
We are talking about a different part
![]() I have been searching for a picture and can't find one yet. The last picture looks like the smaller splined end but I can't remember seeing the threaded section. If that is the shaft the other end had three sections of splines with a full circular clip between two of them, it was these two section that had gone and were bone dry. The challenge is now on to find exactly what was replaced ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
That explains a lot then! Looks like these newer boxes have some sort of other issue then. Other splined components in the LT230 include: Rear output shaft: ![]() Front output shaft: ![]() The centre differential itself: ![]() That's the extent of the shafts within the LT230 (save the intermediate shaft but that isn't splined and doesn't rotate!). Any of those look like your suspect part? If not, then I suspect perhaps we're confused between transfer box and main gearbox? |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
I'm a little concerned now. If the torque of a Puma is too much, I have an IRB vgt that gives 406nm compaired to 359nm of a standard Puma. I wonder how many have had problems with transfer boxes after tuning?
I don't think torque is an issue, as I've stated above LT230s as a design have been putting up with more than what a 4-cylinder diesel can throw at them for many years!
This issue may be something on newer models, I'm starting to think that perhaps we've had a bit of a "lost in translation" issue here and it might be an issue with the main gearbox rather than the transfer box. Bob, if you don't recognise any of the shafts in my post above then how about this: ![]() Click image to enlarge I'm afraid all I have is the workshop manual diagram, but item 7 on the above is the output shaft for the MT82 gearbox. Or the inner part of it anyway, there's another bit that slots over that within the extension housing apparently, and this is what interfaces with the transfer box. |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 333 ![]() ![]() ![]() |
Wonder if it could be the extension shaft - item 22 in the picture below.
![]() This is the adaptor shaft between the gearbox and transfer box. Item 3 bolts onto the gearbox output shaft and the adaptor shaft clips into this. I think the area the adaptor shaft sits in is "dry" so any lubrication for the splines is likely to only be from lubricant applied at assembly. If that is so then it seems a daft design decision - splines need lube. Any misalignment between the gearbox output shaft and transfer box input shaft will cause accelerated wear on the splines between 3 and 22 (ask the owner of any BMW R or K series bike....) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Item 22 it is ![]() The splines on the left hand end in the picture are the ones that had worn away and were bone dry. I have been hunting high and low to find an exploded diagram somewhere. Thanks FH. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Excellent. So it's a poor design on the adaptation of the MT82 for use in front of the LT230. Didn't think there would have been an issue with the latter as it's just about the best drivetrain component Land Rover have put in their vehicles!
Bob, please accept my apologies for going on about the LT230 in the posts on the last few pages, since these were based on the issue being with the transfer box. I think Mr Horseman is correct in that the coupling between the output shaft and the extension shaft is not an oil-immersed joint. The workshop manual simply instructs "Apply anti-seize grease to the splines". Incredibly bad design as pointed out above, however I would think that perhaps there might have been some issue with Bob's particular vehicle to cause the very accelerated wear he has experienced. Ie. they forgot to apply grease or did so incorrectly. Otherwise we would be seeing this happen far more regularly with Tdci vehicles across the board. Very interesting ![]() |
