Home > Maintenance & Modifications > Corrosion Prevention Guide!
Page 61 of 87 <123 ... 606162 ... 858687>
Zagato
This one is REALLY nice, still smells new, it's a 65 plate and the owner works for Land Rover (forum member) he has been meaning to get it to me since he bought it new, which would have saved some rusty edges BUT it is still good enough for Dinitrol Corroheat which is clear/opaque. He can show off his chassis now Thumbs Up
Not a very good picture this morning and it is blacker but gives an idea! Corroheat is used widely from the undersides of brand new Morgan's and restored show cars to the complete exterior of road gritters. It was designed as an engine detailer originally so is also completely heat resistant. Good stuff...
Post #799141 23rd Oct 2019 10:23am
MalithS
Many thanks to Zagato for sorting my 90 out. Brilliant work and highly recommended. Underneath the car is looking great now with the Corroheat applied. Thumbs Up
Ordered my tin of ACF50 this morning to I can keep on top of things as well
Post #799280 24th Oct 2019 10:36am
Sulisuli
Certainly looks very nice Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #799379 24th Oct 2019 9:10pm
Zagato
SNAP! Shocked well nearly, little brother is in for full treatment and a few mods Cool
Both 14 plates.
Post #801602 10th Nov 2019 11:37am
Zagato
This is particularly nice Thumbs Up
And so is the cake, many thanks to Nigel's wife Very Happy delicious Wink
Post #801603 10th Nov 2019 11:39am
Rashers
Thanks for all your hard work on our Defender, Chris. It's safely back into darkest Norfolk now.
Luckily no issues at the border control between Suffolk and Norfolk Rolling with laughter
Glade you like the cake as well as our USW Very Happy Great picture with its little brother. I do like the look of a 90 and if my numbers come up, I will be adding one to my collection to keep our 110 company Laughing
If anyone has been having thoughts about getting their truck protected, Chris has done an A1 job for us. Can't recommend his work highly enough
Thank you again, Chris Thumbs Up
Post #801623 10th Nov 2019 3:34pm
JOW240725
^^^ Rolling with laughter Laughing
Glad you made it safely thru' Suffolk! James
Instagram @suffolk_rovers
Post #801642 10th Nov 2019 5:44pm
Rashers
Me too Thumbs Up Luckily, the draw bridge was down when I reached Elveden Rolling with laughter
Post #801648 10th Nov 2019 6:18pm
G_unit
I know I’m coming into this at the wrong time of year perhaps, but I’ve decided to get the underside of my 90 sorted out before subjecting it to the salty roads where I live, they’ve been out gritting a few times now. I’ve already bought a great load of products from bilt hamber and I’ve started on the underneath today, giving it a thorough clean all over the chassis and going at it with the abrasives. The problem I have is that the truck lives outside, and I want to ensure it’s completely dry before applying anything as I will be using the bilt hamber epoxy mastic so I don’t want to seal anything in. Does anyone have any good tips for making sure it’s bone dry inside and out? My plan is to get under with a heat gun and fill the insides of the chassis firstly with bh atom Mac which is supposed to disperse water, then fill them right up with dynax s50. Then the outside will get a coat of the mastic. I have already treated the few spots of rust that I can see with bh hydrate 80 rust converter. Does this sound anything like or will I start seeing problems in a couple of years? sorry for the novel but I am concerned about this one and am planning on having it as a keeper.
Post #802470 16th Nov 2019 5:51pm
Zagato
Warning g-unit, nothing disperses moisture completely, (its Censored ) apply any solution and it will push water of course BUT moisture "soaks" into metal, especially welds which you have runnning along the entire length of your chassis. Drying is paramount, you will make things worse by covering moisture of course, you will have to decide what is best for this in your circumstances. Not easy if working from home outside without proper equipment! I only used Bilt Hamber once for reasons previously stated, so cannot advice on your products.
Post #804481 2nd Dec 2019 7:19pm
Zagato
One of my regular customers and one of my favourite Defenders. Now refreshed underneath and with a cleaned/polished body Cool Three layers of Underbody Dinitrol and three layers of body wax will keep her mint over winter Very Happy
And something completely different and rotten because somebody had filled the chassis with waxoyl and sealed it in. Never do this, you get condensation in box sections and waxoyl becomes a thick cakey mess in as little as two years and acts like a wet sponge just holding water against the chassis... disaster, much welding and fabricating going on now, nearly finished. Use Dinitrol cavity 1000 treatment folks, yes they have changed the name again! It will never soak up moisture... Waxoyl is a 1960's technology like the car Rolling Eyes simply oil, wax and white spirits Sad
Wet waxoyl cut and peeled back to show wet rust underneath. Waxoyl peeled off other areas showing rot on already replaced fabricated metal. Apart from it becoming soaked as it is only wax and oil which does not resist water after a year or so, it shrinks letting water in down the sides and underneath as it does not seal onto metal.
Post #804483 2nd Dec 2019 7:24pm
Zagato
The whitish/yellow stuff, bottom inside is the wet waxoyl. The moisture has been sitting on the lower sides where the waxoyl has shrunk... and underneath of course, holed also. It was so full of waxoyl, we had drops of it on fire dripping down as we welded. If you have this situation I would open up the drain holes and heat the chassis up, get out as much as you can, then 360 degree spray with ACF-50 then once again with Dinitrol 1000.
Post #804506 2nd Dec 2019 8:33pm
treps
The Adventure is looking excellent. Thank you. I look forward to picking it up tomorrow.
Anyone still with doubts on the effectiveness of the ACF 50 treatment applied by Chris, just look at the end result. Brilliant
[quote="Zagato"]One of my regular customers and one of my favourite Defenders. Now refreshed underneath and with a cleaned/polished body Cool Three layers of Underbody Dinitrol and three layers of body wax will keep her mint over winter Very Happy
Post #804510 2nd Dec 2019 8:54pm
JOW240725
Great looking Adventure Treps Thumbs Up Great work Zagato Bow down Rading these I always wish I had my Defender from new and treated before use and regularly after!
Any plans to move to Suffolk Zagato? Whistle James
Post #804590 3rd Dec 2019 3:26pm
Bluest
For those of us brave/stupid enough to want to do DIY application of Dinitrol, is there any effective way to clean the chassis without access to a steam cleaner? I did mine a few years ago with just a pressure washer and soap and it really doesn't get all the crud off. It needs doing a again now and wondering how to do a better job of cleaning it. 2007 110 TDCi Station Wagon XS
Post #808487 2nd Jan 2020 5:45pm
