Home > Wheels & Tyres > Spare wheel carrier - again !
Page 5 of 6 <123456>
JSG
Mmm, like the look of that. Got any pics without the wheel on Brendan? Do the fix to the original holes on the door? John
2011 Tdci 110 CSW XS
Post #94277 14th Oct 2011 6:29pm
leeds
Sorry John those are the only pictures I have at the moment.
Will try and get some more next week and check on your hole question.
Brendan
Post #94282 14th Oct 2011 6:50pm
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Oo! Would they fit a 110 double cab?
Also how do they attach?
Thanks
leeds wrote:
We can now offer these swing away wheel carriers. Single chassis mounting point. The wheel can be set to either a high or low position.
or
Cost including VAT and delivery would be about �365
My apologies, turn your screen through 90 degrees. They are the right way in photobucket. My IT guru is busy at the moment. To errr is human to ...................
Brendan
Post #94286 14th Oct 2011 7:31pm
leeds
Thanks
Sorry I can not answer your questions at the moment.
I saw this one about 3 months ago before it went into production. Now they have started to produce them and have some on the shelf! Will get more photos and information next week.
Brendan
Post #94287 14th Oct 2011 7:39pm
airpusher
Thanks for the reply.
No rush, I'm just settlingbwith my first defender.
Post #94288 14th Oct 2011 7:43pm
Morea
Be aware of the issue. I am interested in this restraint, simple and beautiful Thumbs Up http://www.clublandrovertt.org/index.php?a...ype=avatar
Post #95102 19th Oct 2011 7:26pm
leeds
OK I know it has taken some time to get photos.
Here is one of the bare wheel carrier. To swop from high position to low all you do is swop the receiver mount through 180 degrees.
You can also see the size of the bottom mount. For a single pivot mount carrier it does have to be reasonably beefy
Brendan
Post #98820 8th Nov 2011 7:42pm
markb110
Hi Brendan
Looking good - like the idea of rotating the fitting to allow larger tyres
Just a thought - could a fitting be made to attach to the reciever to take a bike carrier. The advantage would be that the bike and carrier would allow the door to open which the tow hitch versions do not.
Mark
Post #98859 8th Nov 2011 9:17pm
Morea
Post #98866 8th Nov 2011 10:03pm
SGH
Does anyone know who does a wheel carrier for a 130 ?
Simon 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #98904 9th Nov 2011 9:14am
JSG
130 wheel carrier is no different to a 110 / 90 carrier (obviously the tailgat rather than rear door version). John
Post #98907 9th Nov 2011 10:05am
leeds
John, a standard 90/110 pick up wheel carrier will NOT fit a 130.
The rear cross member is fully under the rear tub.
it would require a big bracket fitted to rear cross member to extend to back of the tub. The problem I would envisage is the leverage effect of weight of spare wheel.
It could be done, however Safari Equip have never done one as they have never been asked for one. So it would be a special one off Simon and costs quite high.
However Simon if you bought a standard one and knew a good fabricator/welder it would be possible to have one done yourself.
I understand from the factory that the single pivot ones are ready to go. i.e. parts on shelves, much easier to store parts then assembled ones.
Brendan
Post #98923 9th Nov 2011 11:58am
SGH
Any idea who makes this one?
Post #98945 9th Nov 2011 3:26pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Me Thumbs Up but AndrewS extended his cross member out to suit. The problem with using a standard Safari equip one as Brendan suggests is you would have no way of locking it closed as that type relies on using the back door , so it won`t work on a pickup / double cab 90-110-130.
Post #98949 9th Nov 2011 3:42pm
Sonic3d
I wonder where they got (copied) that idea from Whistle
Post #98950 9th Nov 2011 3:47pm
