Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1415 |
I may have read the message wrong, when it said
I thought he may have been referring to fitting the parts needed for ambient lighting as well as the screen, just to be clear you can't enable ambient lighting if the parts aren't there Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
14th Dec 2022 12:29am |
abyss Member Since: 30 Sep 2017 Location: Melbourne Posts: 29 |
Yes correct. I’m planning to order the actual light strips and fit into the trims. There is video from powerfuluk that fitted the light strip in the dash and the plug is already in the car. I think Simon mentioned it needs activation.
14th Dec 2022 9:37am |
pllr Member Since: 22 Nov 2022 Location: PA Posts: 24 |
Got it, sorry about that. In that case it may work! When I changed that setting in our P300, I was able to see the ambient light UI in Pivi. It just didn't do anything. |
14th Dec 2022 3:38pm |
Great. That’s a good sign.
14th Dec 2022 7:52pm |
umbertob Member Since: 21 Jun 2020 Location: Altadena, CA Posts: 133 |
MultiCAN-745 Tailgate Remote Release
Current: Not Supported New: Enabled My app hangs when I try modifying the above line of the CCF, freezing at 0% as soon as I touch Yes in "Upload these Changes?" Only way to get the app back is to force close and restart it. Tried several times, same result. Using Android and the latest beta tool firmware and app versions on a 2020 NAS 110 P400. Are you guys able to successfully modify that line, and does it enable the elusive remote button to open the tailgate (it currently does nothing in my remote)? 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround |
16th Dec 2022 4:49am |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 422 |
@umbertop
I also need this function urgently, Hope you and Patrick will solve the above mentioned. After my Respray/rebuild I did make a bypass on the wire to the Tailgate handle switch. For an extra switch in the cargo area I thought the connector was property clicked together but the doorhandle release switch is not functioning anymore. My car has a full Bulkhead, so no way to get in. Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
16th Dec 2022 11:52am |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 |
I worked with Patrick a bit on that and pointed out Simon's video as well, but we never could get it to work. I had the same problem where it would hang trying to update that value. It seemed to only hang when I was just changing that single value. I combined it with a few other changes and it accepted it.
Unfortunately, it's still not working. I suspect there's a combination with another value about the boot type that's the key to it working. I'm still working on that and ACC to come up with fixes for both. 20MY Defender 110 Fuji White |
16th Dec 2022 2:37pm |
I can make the change MultiCAN-745 Tailgate Remote Release on mine and it uploads OK but it has no effect on the opening of the rear door via the remote Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
16th Dec 2022 11:23pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
Chaps, can one enable the paddle shifters via the Gap tool? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
19th Dec 2022 7:16am |
Pat at Gap can probably answer that better but I would say yes, eventually! I don't think anybody has done it yet with the IID tool but the other guys who are using the JLR Pathfinder software to do it have succeeded so that proves it's capable of being done. There are some settings visible with the IID tool but none I can see to enable the paddles, the only reference I can find for the paddles is
MultiCAN-536 GearboxPaddlesInDrive Active in Drive Which relates to how the paddles work either in drive or in sport or both. If there are any further settings that need changing I'm sure GAP with uncover them given time, remember this is still a beta test. Also I take it you know that you would need to fit the Alcantara V8 steering wheel as the standard wheel doesn't have the cut-out for the paddles. Powerful have a kit in for the paddles https://www.powerfuluk.com/vehicles/land-r...wheel.html and they sell the Alcantara V8 wheel https://www.powerfuluk.com/vehicles/land-r...-l663.html Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
19th Dec 2022 3:10pm |
^ thanks for that.
I tried to twist the arm of the selling dealer to retrofit it, but they had to contact LRSA, who told them under no circumstances should they do this because "it's not in the approved accessories list", and it would void the warranty. bunch of fluffing morons -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
19th Dec 2022 4:06pm |
zhihong.james Member Since: 14 Apr 2022 Location: Calgary Posts: 7 |
I was working on adding an activity key to my 23 110X, went into the "service/test", but I didn't see any options except the "vehicle reset".the vehicle was in service mode and the tool was connected.
Any pointers guys? |
24th Dec 2022 9:59pm |
OVRLANDR Member Since: 16 May 2022 Location: New York Posts: 42 |
I believe you are supposed to go to your In-Control App and put the vehicle in service mode first. Then try adding the key through GAP in that order. If it doesn’t work at first, keep trying the same steps.
24th Dec 2022 10:40pm |
The vehicle is in service mode and according to powerfuluks video the "Romote Function Actuator" should show up even before that. I just didnt see it except the "vehicle reset" option.
24th Dec 2022 10:45pm |
