Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement
Page 13 of 109 <123 ... 121314 ... 107108109>
pllr
United States
Hairy Dan wrote:
abyss wrote:
Does anyone know the IID tool config menu has the option to switch from 10" to 11.4" screen? and Ambient lighting enable?
There is a setting in the ccf which is as follows on my car with the small screen
MultiCAN-641 FrntUpperDispVariant
Panasonic 10 Inch Single View
This is from another forum members CCF file and he has the larger screen
Alpine 11.6 inch Single View
Whether that is all that is needed to activate the larger screen I don't know, I know some of the other companies who are offering activations etc have fitted the larger screens so it certainly is possible but I don't know of anybody who has done it with the IID tool (yet!)
The same applies with ambient lighting there is a setting in the ccf to activate it but as my car already has it I'm not sure whether this would switch it on or you would need further changes
EUCD-240 Ambient Lighting
Tri colour fitted, auto button disabled
I would say that most things will be able to be activated/installed in time but you have to remember that it is still in the early stages of beta testing at the moment Thumbs Up
We have a P400 with ambient lighting from the factory and a P300 without. I tried the EUCD-240 setting in the P300, and it had no effect, i.e., I think the different color ambient lighting is different hardware.
Post #974610 13th Dec 2022 10:11pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I may have read the message wrong, when it said
Quote:
order the parts and retrofit it
I thought he may have been referring to fitting the parts needed for ambient lighting as well as the screen, just to be clear you can't enable ambient lighting if the parts aren't there Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #974614 14th Dec 2022 12:29am
abyss
Australia
Yes correct. I’m planning to order the actual light strips and fit into the trims. There is video from powerfuluk that fitted the light strip in the dash and the plug is already in the car. I think Simon mentioned it needs activation.
Post #974624 14th Dec 2022 9:37am
pllr
United States
Got it, sorry about that.
In that case it may work! When I changed that setting in our P300, I was able to see the ambient light UI in Pivi. It just didn't do anything.
Post #974661 14th Dec 2022 3:38pm
abyss
Australia
Great. That’s a good sign.
Post #974686 14th Dec 2022 7:52pm
umbertob
United States
MultiCAN-745 Tailgate Remote Release
Current: Not Supported
New: Enabled
My app hangs when I try modifying the above line of the CCF, freezing at 0% as soon as I touch Yes in "Upload these Changes?" Only way to get the app back is to force close and restart it. Tried several times, same result. Using Android and the latest beta tool firmware and app versions on a 2020 NAS 110 P400. Are you guys able to successfully modify that line, and does it enable the elusive remote button to open the tailgate (it currently does nothing in my remote)? 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround
Post #974812 16th Dec 2022 4:49am
Defendit..
Netherlands
@umbertop
I also need this function urgently, Hope you and Patrick will solve the above mentioned.
After my Respray/rebuild I did make a bypass on the wire to the Tailgate handle switch.
For an extra switch in the cargo area
I thought the connector was property clicked together but the doorhandle release switch is not functioning anymore.
My car has a full Bulkhead, so no way to get in.
 No Mud flaps for my 90.!
P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #974859 16th Dec 2022 11:52am
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
I worked with Patrick a bit on that and pointed out Simon's video as well, but we never could get it to work. I had the same problem where it would hang trying to update that value. It seemed to only hang when I was just changing that single value. I combined it with a few other changes and it accepted it.
Unfortunately, it's still not working. I suspect there's a combination with another value about the boot type that's the key to it working. I'm still working on that and ACC to come up with fixes for both. 20MY Defender 110 Fuji White
Post #974880 16th Dec 2022 2:37pm
Hairy Dan
New: Enabled
I can make the change MultiCAN-745 Tailgate Remote Release on mine and it uploads OK but it has no effect on the opening of the rear door via the remote Sad Cheers Ian
Kielder 4x4 Safari
Post #974942 16th Dec 2022 11:23pm
Naks
Chaps, can one enable the paddle shifters via the Gap tool? --
Post #975093 19th Dec 2022 7:16am
Hairy Dan
Pat at Gap can probably answer that better but I would say yes, eventually! I don't think anybody has done it yet with the IID tool but the other guys who are using the JLR Pathfinder software to do it have succeeded so that proves it's capable of being done. There are some settings visible with the IID tool but none I can see to enable the paddles, the only reference I can find for the paddles is
MultiCAN-536 GearboxPaddlesInDrive
Active in Drive
Which relates to how the paddles work either in drive or in sport or both. If there are any further settings that need changing I'm sure GAP with uncover them given time, remember this is still a beta test.
Also I take it you know that you would need to fit the Alcantara V8 steering wheel as the standard wheel doesn't have the cut-out for the paddles. Powerful have a kit in for the paddles
https://www.powerfuluk.com/vehicles/land-r...wheel.html
and they sell the Alcantara V8 wheel https://www.powerfuluk.com/vehicles/land-r...-l663.html Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #975143 19th Dec 2022 3:10pm
Naks
^ thanks for that.
I tried to twist the arm of the selling dealer to retrofit it, but they had to contact LRSA, who told them under no circumstances should they do this because "it's not in the approved accessories list", and it would void the warranty.
bunch of fluffing morons Rolling Eyes --
Post #975152 19th Dec 2022 4:06pm
zhihong.james
Canada
I was working on adding an activity key to my 23 110X, went into the "service/test", but I didn't see any options except the "vehicle reset".the vehicle was in service mode and the tool was connected.
Any pointers guys?
Post #975697 24th Dec 2022 9:59pm
OVRLANDR
United States
I believe you are supposed to go to your In-Control App and put the vehicle in service mode first. Then try adding the key through GAP in that order. If it doesn’t work at first, keep trying the same steps.
Post #975699 24th Dec 2022 10:40pm
zhihong.james
Canada
The vehicle is in service mode and according to powerfuluks video the "Romote Function Actuator" should show up even before that. I just didnt see it except the "vehicle reset" option.
Post #975700 24th Dec 2022 10:45pm
