![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
gremmieboi Member Since: 07 Dec 2022 Location: Dallas Posts: 3 ![]() |
Thank you, Ian. I’ll start there and report back!
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 67 ![]() ![]() ![]() |
There's also a setting for AFS123 that seems to impact headlight settings.
MultiCAN-674 AFS123 AFS123 Enabled/Disabled Not sure what it does though. 20MY Defender 110 Fuji White |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2724 ![]() ![]() |
Two things I’d be interested to know if they can be disabled by this tool:
Emergency lane keep assist - can turn it off in PiviPro but it defaults back to on at each ignition cycle annoyingly. Same goes for emergency braking Auto-mirror fold |
umbertob Member Since: 21 Jun 2020 Location: Altadena, CA Posts: 133 ![]() ![]() |
Isn't that (AFS123) an AC Delco branded oxygen sensor? ![]() |
OVRLANDR Member Since: 16 May 2022 Location: New York Posts: 45 ![]() ![]() |
I’m having the same issue with Dynamic mode…interior lighting turns to red but gauges stay the same. I wonder if there is something that changes in the CCF for the digital dash? I’m going to look at MultiCAN-506 ClusterAlertGFX tomorrow. Last edited by OVRLANDR on 9th Dec 2022 4:18am. Edited 1 time in total |
It's the headlight type. They're supposed to switch between city/country/roadway beam patterns by design. I've been doing a little research since my last post. Disabled by default apparently. EUCD-014 Headlights, Type Matrix LED AFS123/IHB 20MY Defender 110 Fuji White |
Ok, so I tried the MultiCAN-506 ClusterAlertGFX to see if that would give me the red gauges in Dynamic mode. I thought that this CCF was cluster alert graphic but no love there with any changes.
pllr Member Since: 22 Nov 2022 Location: PA Posts: 24 ![]() ![]() |
I have done the Dynamic settings in our two Defenders. In the P400 with the full digital gauge cluster, I do not get any red markings. I see the Dynamic selection screen for a few seconds and then the dynamic icon. That car has the custom ambient lighting and turns red in the cabin when the dynamic mode is selected.
In our P300 with the digital/analogue hybrid gauge cluster, the digital part shows the dynamic icon and has a red "glow" effect. That car does not have the custom ambient lighting, so the lighting in the cabin doesn't change. Is something else supposed to change in the full digital gauge cluster? |
Bob Heijnen Member Since: 29 Nov 2022 Location: Noordwijk Posts: 17 ![]() ![]() |
Does anyone figured out yet how to activate configurable TR2 with the IIDtool?
Would very much like to get it activated. |
abyss Member Since: 30 Sep 2017 Location: Melbourne Posts: 33 ![]() ![]() |
Hi All,
Great forum and topic. My P400S has been built and waiting to be shipped. Should get it in Feb. (long way to Australia). I couldn't ordered the 11.4" and ambient lightings due to the shortage. Does anyone know the IID tool config menu has the option to switch from 10" to 11.4" screen? and Ambient lighting enable? Want to make sure before I go and order the parts and retrofit it. Thanks heaps. |
I do see CCF files on GAP however, I’m not sure if those files have been activated to change the software.
I have the 11.4” screen from the factory and in GAP on EUCD - Front Center Mounted Display it states not supported. There’s also a MultiCAN - 466 TouchPanel (also states not fitted) but, I’m not sure at this point all of what needs to be activated. So I think everything is there to enable the screen. |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1442 ![]() ![]() ![]() |
Did you try the settings I told you about on 6th, if you have and it's still not working then no, it is not able to be activated just yet. Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
There is a setting in the ccf which is as follows on my car with the small screen MultiCAN-641 FrntUpperDispVariant Panasonic 10 Inch Single View This is from another forum members CCF file and he has the larger screen MultiCAN-641 FrntUpperDispVariant Alpine 11.6 inch Single View Whether that is all that is needed to activate the larger screen I don't know, I know some of the other companies who are offering activations etc have fitted the larger screens so it certainly is possible but I don't know of anybody who has done it with the IID tool (yet!) The same applies with ambient lighting there is a setting in the ccf to activate it but as my car already has it I'm not sure whether this would switch it on or you would need further changes EUCD-240 Ambient Lighting Tri colour fitted, auto button disabled I would say that most things will be able to be activated/installed in time but you have to remember that it is still in the early stages of beta testing at the moment ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks so much for looking into it for me.
Hope the tool can do this as i can order the part and fit it myself. |
