Page 1332 of 1381 <123 ... 133113321333 ... 137913801381>
L110CDL
It's a wrap around, a QT one Thumbs Up Clayton.
Keeper.
Post #948725 8th Apr 2022 9:54pm
geobloke
L110CDL wrote:
I had the fright of my life while driving to work on Wednesday morning, going along about 50-55 mph and there was one mighty crash / banging noise from under Millie, my first thoughts were propshaft or something along those lines, something caught my eye in the drivers mirror, a big lump of metal flying across the road to the other side, thank god no one was behind me or coming the other way. I was lucky in the fact that i pulled over straight away onto a wide grass verge so i was completely off the road, got out and had a good look around Millie, she seemed all in tack, so i walked up the road to retrieve this big lump of metal, it was my front diff guard Shocked still intact and in it's right shape, picked it up and carried onto a layby to have a good look under Millie to make sure she was all ok as i could not on the grass verge, all good and carried onto work.
I stopped off at my indy on the way home from work and told him what happened and he had never heard of this ever happening, so were not sure how the bolts came loose Whistle My indy will put it back on in a weeks time when Millie goes in for a 6,000 mile service Very Happy
Has anyone here ever heard of one of these just coming off, no warning noises, just flying off Question
Woooooah... Bet that made a lot of noise. I have never known a QT style diff guard to come off. Have had them on both my Defenders and they are solid. Best diff guards IMHO too...
Weird...
But I do sympathise about the noise. In my younger days I Eva (previous 90) chewed up a rear UJ, so took the prop off and because I desperately needed to get to the office I tightened up the transmission brake, chucked Eva in to diff lock and drove off. Pretty chuffed with myself.
Until... Rolling Eyes The transmission brake drum nuts unscrewed and the drum hit the road (in the middle of the high street) with an almighty clang and rolled back down the hill, clanging all the way... It really would have made an amazing tv sketch. Got to get the drum, but have no hand brake on a hill and overlooked by many people out shopping Rolling with laughter
Oh my... Rolling Eyes
Post #948742 9th Apr 2022 7:40am
L110CDL
It did make a lot of noise, more than when my front prop shaft tried to come through the floor plate under my feet Shocked
The diff guard has been on 10 + years with not one problem, so i'm thinking it was " helped " to come off Mad Clayton.
Keeper.
Post #949059 11th Apr 2022 8:10pm
Same as what I have Clayton.
Has it been impacted a little greenlaning? That may have something to do with it but maybe not, itโ€™s difficult to say.
The clamp on round ones are renowned for coming off which is why I went for the QTโ€™s as well.
I would imagine the lowermost bolts have came loose first, as they are fitted almost vertically with the head nearest the ground. No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #949074 11th Apr 2022 9:12pm
kenzle8a
Utter Censored of a job but I rebuilt the fuel pressure regulator, there was a semi significant diesel leak that appeared last week.
I used a rebuild kit form x8r as the replacement part was on back order, it wasnโ€™t that hard to rebuild one it was off the truck.
Thus far 100 miles in it seems to have done the trick but Iโ€™m keeping a close eye on it.
Post #949076 11th Apr 2022 9:21pm
landy andy
Turner Engineering have FPRs in stock. Thumbs Up
Post #949089 12th Apr 2022 6:00am
excossack
or Duckworths where I got mine from. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #949123 12th Apr 2022 9:37am
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Fitted a set of Uproar4x4 Renegade stainless steel rocksliders. Pricey, but worth the premium in my opinion. Arrived in 48 hours, in exceptionally thorough packaging (a bit ironic given their purpose, but I suppose we all like stuff to be pristine on arrival!); superb finish; supplied with clear, well-illustrated fitting guidance, and loads of spare fittings. Very solid, with plenty of fitting tolerance in the supports, which was just as well. My nearside and offside turned out to be noticeably different in shape and size.
I'm very pleased. I've been able to do away with my beaten up sills and rusty side steps, mostly jammed solid after impacts (ahem). It will be a shame when the rocksliders get knocked, but that is the point...
I am thinking that some judicious application of non-slip bed liner might provide a bit of protection to the coating from grubby shoes, and enable them to function as step substitutes.
No connection to Uproar4x4!
Post #949274 13th Apr 2022 1:41pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
oooh.. got a pic? I'm in the market for some sliders (mainly for side impact protection)
Today has been quite productive. Having had wipers go haywire on Tuesday, quickly ordered parts to overhaul as MOT is Tuesday, but on extracting the dash I find that this nut had come loose causing the issues, so didn't need a full strip out (phew) just some fettling. Used the new arms and blades to smarten her up on the outside. and now have a spare motor wheel boxes and crank
on the shelf
All wipers and washers now fully functioning Thumbs Up
Next started to look at my inter-cooler which has been a state since I bought her a year ago.... To be honest I'm amazed it wasn't blowing:
Frame supports are a mess so cleaned them up
Just letting them dry overnight and in the morning a nice shiny new Mahoosive inter-cooler is going in Whistle
Post #949485 15th Apr 2022 6:57pm
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Made myself a nice new set of jump leads and fitted an Anderson connector in the engine bay. Too much time spent wrestling with bloody convoluted tubing meant I ran out of time to connect it all up to the battery, but itโ€™s ready to go.
Post #949502 15th Apr 2022 8:59pm
I often do the same with some wiring stuff, do it in stages sometimes makes it that bit easier and a a nicer job to do.
A bit one day and the rest another. No Guts, No Glory.
Post #949512 15th Apr 2022 10:07pm
MussEd
Iโ€™d like to claim that I planned to do it in careful stages! Reality is Iโ€™m just slow, inexperienced and a bit scared!
Post #949518 15th Apr 2022 11:06pm
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Today?? ... Well actually the last three days on and off Exclamation
Since purchasing my Defender 90 back in October I've been doing "something" most days. But the last three days I've done seven oil changes and two filter changes.
Then did a test run for leaks and found my radiator had sprung a leak Crying or Very sad
So, the seven oil / filter changes ... a new radiator then decided on new coolant hoses and a new Oil breather filter.
Then round the block again ... and NO leaks to date Whistle
Enjoy the weekend Thumbs Up 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #949589 16th Apr 2022 6:45pm
gcc130
Why seven oil changes in three days?
Post #949590 16th Apr 2022 7:00pm
Cubflyer
Hi GCC
2x Swivel Housings
2x Axle Diffs
Transfer GB
R380 GB
Engine + Filter
Fuel Filter
... and a Coolant change
John 2010 Defender 90 300Tdi CW (White/1994)
Post #949591 16th Apr 2022 7:05pm
