Page 1333 of 1384 <123 ... 133213331334 ... 138213831384>
mini Anaconda
Silicone hoses look good Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #949594 16th Apr 2022 7:50pm
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Yes, very pleased with them and "Stoney Racing" who supplied them. Ordered at 1:30pm and arrived at 9:30am next day simply by Royal Mail 24. The quality good and hose clips quality too. 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #949597 16th Apr 2022 7:55pm
LR90XS2011
decided to do a oil and filters change, and whilst I was doing the fuel filter with the rear wheel off I decided to fit the Gwyn Lewis front of rear tub protectors.
These had been sat in the garage for a couple of years whilst I plucked up the courage to drill the tub, now have a full set protecting all my outriggers
 DEFENDER 90 TDCI XS,
Post #949665 17th Apr 2022 5:45pm
excossack
Decided to change the brake pads on the 110. All going well. Rear done.
Drivers side front done.
Passenger side half done. Decided to try and clean up the pistons. The outer half went OK, then tackled the inner half and pressed the brake pedal too far and the piston now wont go back in. Its kinda stuck....No amount of force wont put the piston back in its home.
Looks like this...
Also think the discs might be needed.
Sad 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #950015 21st Apr 2022 5:58pm
FWIW I always keep an old and very worn set of pads on hand which can be fitted if it is ever necessary to extend the pistons in order to prevent them popping all the way out. I actually thought that even if the pistons press against the disk they won't pop out, so I am not entirely sure what has caused yours to stick.
Post #950019 21st Apr 2022 6:38pm
Dinnu
excossack, it could jam by what is called a drawer effect. Since there is not much piston in the bore, the piston could slightly ‘rotate’ and jam in the bore. Try to push it in from different positions around its circumference and see if that does the trick. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #950020 21st Apr 2022 6:57pm
excossack
Maybe the last pedal push was a push too far!. I did try changing the angle of attack but the piston would not move. It feels like the piston is rocking, but when I am using a crow bar to try and lever the piston back in, I think something is certainly wrong.
Also the bottom piston didnt seem to move or anywhere near the same movement as the top piston
Also I think new discs on the front are needed. Deep joys! 1999 Defender TD5 110
Regards
John M0VAZ
Post #950026 21st Apr 2022 7:51pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Well today was MOT day.
Pass!
Advisories on brand new wiper blade (seems to be a mnfr fault), and Trackrod end ball joint dust cover on nearside damaged but preventing the ingress of dirt.
Are these covers an easy job? Haven't looked at it yet
Post #950059 21st Apr 2022 10:19pm
jedIKnight
United Kingdom 2001 Defender 110 2.5 TD DCPU Bonatti Grey
Posted twice oops
Post #950554 25th Apr 2022 10:15pm
jedIKnight
NATO Hitch sorted, now its time for trailer conversion to begin.
Post #950555 25th Apr 2022 10:16pm
Naks
Celebrated Freedom Day on the trail at Helderberg Farm Thumbs Up
Highlights of the outing: https://www.instagram.com/reel/Cc27hwIN9M0/ --
Post #950819 28th Apr 2022 8:27am
jedIKnight wrote:
That unsupported drop-frame is terrifying and wrong in so many ways! Shocked
Post #950864 28th Apr 2022 2:50pm
jedIKnight
Maybe to the untrained eye but I just swap out the top one for the bottom one when using standard ball hitch. Direction of force straight line.
Post #950866 28th Apr 2022 3:13pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
jedIKnight wrote:
... the untrained eye ...
LOL where's the popcorn Roaming around 🇳🇴🇨🇭
Post #950868 28th Apr 2022 3:17pm
I wasn't really bothered about the untrained eye, I was basing the observation on my eye, which is far from untrained! Rolling with laughter
As long as you don't use any coupling in the lowest position.
I take it that you don't venture into any demanding off-road conditions as a rule? The straightness of the drop frame, step, and cross-member is surprising if you do.
Post #950870 28th Apr 2022 3:41pm
