Home > My Defender > What Did You Do In Your Defender Today |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10830 |
It's a wrap around, a QT one Clayton.
8th Apr 2022 9:54pm |
Woooooah... Bet that made a lot of noise. I have never known a QT style diff guard to come off. Have had them on both my Defenders and they are solid. Best diff guards IMHO too... Weird... But I do sympathise about the noise. In my younger days I Eva (previous 90) chewed up a rear UJ, so took the prop off and because I desperately needed to get to the office I tightened up the transmission brake, chucked Eva in to diff lock and drove off. Pretty chuffed with myself. Until... The transmission brake drum nuts unscrewed and the drum hit the road (in the middle of the high street) with an almighty clang and rolled back down the hill, clanging all the way... It really would have made an amazing tv sketch. Got to get the drum, but have no hand brake on a hill and overlooked by many people out shopping Oh my... |
9th Apr 2022 7:40am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20538 |
Same as what I have Clayton.
Has it been impacted a little greenlaning? That may have something to do with it but maybe not, itโs difficult to say. The clamp on round ones are renowned for coming off which is why I went for the QTโs as well. I would imagine the lowermost bolts have came loose first, as they are fitted almost vertically with the head nearest the ground. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
11th Apr 2022 9:12pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Utter of a job but I rebuilt the fuel pressure regulator, there was a semi significant diesel leak that appeared last week.
I used a rebuild kit form x8r as the replacement part was on back order, it wasnโt that hard to rebuild one it was off the truck. Thus far 100 miles in it seems to have done the trick but Iโm keeping a close eye on it. Click image to enlarge |
11th Apr 2022 9:21pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5758 |
Turner Engineering have FPRs in stock.
12th Apr 2022 6:00am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5868 |
or Duckworths where I got mine from. 1999 Defender TD5 110
12th Apr 2022 9:37am |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 164 |
Fitted a set of Uproar4x4 Renegade stainless steel rocksliders. Pricey, but worth the premium in my opinion. Arrived in 48 hours, in exceptionally thorough packaging (a bit ironic given their purpose, but I suppose we all like stuff to be pristine on arrival!); superb finish; supplied with clear, well-illustrated fitting guidance, and loads of spare fittings. Very solid, with plenty of fitting tolerance in the supports, which was just as well. My nearside and offside turned out to be noticeably different in shape and size.
I'm very pleased. I've been able to do away with my beaten up sills and rusty side steps, mostly jammed solid after impacts (ahem). It will be a shame when the rocksliders get knocked, but that is the point... I am thinking that some judicious application of non-slip bed liner might provide a bit of protection to the coating from grubby shoes, and enable them to function as step substitutes. No connection to Uproar4x4! |
13th Apr 2022 1:41pm |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
oooh.. got a pic? I'm in the market for some sliders (mainly for side impact protection)
Today has been quite productive. Having had wipers go haywire on Tuesday, quickly ordered parts to overhaul as MOT is Tuesday, but on extracting the dash I find that this nut had come loose causing the issues, so didn't need a full strip out (phew) just some fettling. Used the new arms and blades to smarten her up on the outside. and now have a spare motor wheel boxes and crank on the shelf All wipers and washers now fully functioning Click image to enlarge Next started to look at my inter-cooler which has been a state since I bought her a year ago.... To be honest I'm amazed it wasn't blowing: Click image to enlarge Click image to enlarge Frame supports are a mess so cleaned them up Click image to enlarge Click image to enlarge Just letting them dry overnight and in the morning a nice shiny new Mahoosive inter-cooler is going in |
15th Apr 2022 6:57pm |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 354 |
Made myself a nice new set of jump leads and fitted an Anderson connector in the engine bay. Too much time spent wrestling with bloody convoluted tubing meant I ran out of time to connect it all up to the battery, but itโs ready to go.
15th Apr 2022 8:59pm |
I often do the same with some wiring stuff, do it in stages sometimes makes it that bit easier and a a nicer job to do.
A bit one day and the rest another. No Guts, No Glory. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
15th Apr 2022 10:07pm |
Iโd like to claim that I planned to do it in careful stages! Reality is Iโm just slow, inexperienced and a bit scared!
15th Apr 2022 11:06pm |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 |
Today?? ... Well actually the last three days on and off
Since purchasing my Defender 90 back in October I've been doing "something" most days. But the last three days I've done seven oil changes and two filter changes. Then did a test run for leaks and found my radiator had sprung a leak So, the seven oil / filter changes ... a new radiator then decided on new coolant hoses and a new Oil breather filter. Then round the block again ... and NO leaks to date Click image to enlarge Enjoy the weekend 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
16th Apr 2022 6:45pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 753 |
Why seven oil changes in three days?
16th Apr 2022 7:00pm |
Hi GCC
2x Swivel Housings 2x Axle Diffs Transfer GB R380 GB Engine + Filter Fuel Filter ... and a Coolant change John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
16th Apr 2022 7:05pm |
