Home > My Defender > 1988 Shire Blue Landrover 90 Restoration
Page 17 of 27 <123 ... 161718 ... 252627>
Co1
Couldn’t agree more. All the best to you Darren.
Post #935060 25th Dec 2021 9:12pm
Dinnu
Thank you Col Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #935063 25th Dec 2021 9:40pm
Very nice indeed Very Happy Darren
Post #935069 25th Dec 2021 10:57pm
Dinnu
Thank you Darren.
Managed to get permission to spend time with my other loved one Laughing
Heart transplant well in progress. The goal now is to get it beating again Very Happy
Post #935171 26th Dec 2021 5:35pm
L110CDL
Nice job on the sump and agree with you on " better than watching a movie " Thumbs Up
Looking proper with the engine in place now Dinnu Bow down 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #936184 3rd Jan 2022 8:09pm
Dinnu
Thank you Clayton, was busy with some small stuff around the 90... getting the remaining of the wires in, like reverse light, fuel sender, got the fuel filter and tubing (but awaiting for a series type lift pump, as the old one, the diaphragm has hardened and the 'new' engine has the 200tdi type of lift pump - different location of inlet/outlet ports). I am planning to test the injection pump and injectors before I install the head. Got the hard brake pipes installed, got the front springs, dampers and turrets installed too. And accelerator cable, brake vacuum etc. Forgot to take pictures though.
It is quite hard to remember where every clip was, and if the cables were above or below the pipes.. those kind of head scratching.
Today got the starter motor and a few small parts painted Very Happy 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #936191 3rd Jan 2022 8:39pm
L110CDL
Your really making progress with the little things which always take up more time than they should do Rolling Eyes
It's always best to test before as things could go very wrong Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #936193 3rd Jan 2022 8:45pm
JOW240725
Sounds like you're making good progress. Thumbs Up James
Instagram @suffolk_rovers
Post #936238 4th Jan 2022 8:28am
Dinnu
Getting ready to prime the fuel....even though unsure when the lift pump will get delivered Mad
Just need to remember to put a new fuel filter before any attempt Rolling with laughter
Adding latest pic from engine bay.
Fuel tank is ready to get some diesel.
Post #936355 4th Jan 2022 8:17pm
L110CDL
Your getting nearer Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #936518 5th Jan 2022 8:31pm
Dinnu
So yesterday collected a bit of Landrover parts from the galvanizers. They have been hot dipped. And boy they look beautiful.
The eagle eyed can surely detect that some parts are not from 1988. Thats because I finally fed up of closing my eyes every time I open the Puma bonnet. So a bit to TLC going to the front end of the Puma. Just in case you question how bad it was, here are some pics.
PS. My good friend, he also travelled with me when picking up the Puma, saw me dismantling, and he started searching online for what mental condition I might have. Unsure if there is anything like Rustiphobia.
Post #937456 13th Jan 2022 6:58am
Dinnu
Fuel system is primed Very Happy all the way to injector pipes and so far seems to be good. Had a small leak from the outlet connection of the lift pump, but a little extra nip seems to have solved it. I guess I was scared of stripping the threads as it is a chinesium alloy Whistle owe and getting the lift pump installed meant I had to take the mounting plate from the original engine (the new engine had the 200tdi type of lift pump) as the depths are different.
So next will be to get the cylinder head sorted....and once that is done and installed, I was thinking I would fire it up for a few seconds without coolant, so no water pump etc. so I can also check the timing belt. But unsure what to do with the oil cooler ports. Blank them off, or fit the radiator, which would then be in the way and afraid of accidentally damaging it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #938561 20th Jan 2022 6:48pm
Dinnu
Glad that I tested the fuel system. Found a small leak from the fuel injection pump drive shaft seal. Will get a new seal and see how it goes again.
In the meantime, paid some attention to the cylinder head. After a good cleanup, lapped the valves, checked all seating all good.
So here, 6 more to go:
All valves in. Some collets seem to have a mind of their own Very Happy
New swirl chambers are in too
So now it is time to fit the head on to the engine..... to be continued. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #938825 22nd Jan 2022 12:59pm
Co1
Great work Dinnu. Thumbs Up
Post #938826 22nd Jan 2022 1:06pm
Dinnu
Thanks Col.
Managed to find some time, and put the head on.
Last peep at the pistons before closing them in. I hope I do not need to see them again any time soon 🤪
Head bolts only nipped up as still need to clean and install the rocker shaft.
Post #938889 22nd Jan 2022 7:50pm
