![]() | Home > Maintenance & Modifications > Puma Gearstick rattle / vibration cure guide (with photos) |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 ![]() ![]() ![]() |
Reviving old thread - Slickshift now available for the Puma Defender:
https://secure.bellautoservices.co.uk/stor...ickshifts/ |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2663 ![]() ![]() ![]() |
Err, Sadi, these have been available for a while now.
I ordered one from Synchro Gearboxes about 3 months ago, massive improvement with the gearshifts! -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
DEF110DCPU Member Since: 06 Aug 2008 Location: ODK Posts: 18 ![]() ![]() ![]() |
thanks to this thread, rattle is stopped!
5 min work, no special tools needed TOP! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20651 ![]() ![]() |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 ![]() ![]() ![]() |
Another happy Customer
![]() the super glueing also sorted my vibration problem so great news. If it helps, I used a pair of levers used to change a bicycle tyre to help replace the gearstick gaitor and it worked a treat. Sweatysock ------------- 110 CSW TDCI (Puma) 2007 |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Thanks here too. I just used my fingers to get the gaiter back on.
[Wanted - new fingers in good condition - please apply Joe the Plumber...!] |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
I’ve just joined this club. It was great to find a job at the right level for my technical ability. I even got the gaitor back on without breaking anything. Hurrah! Thanks for the clear instructions.
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 ![]() ![]() ![]() |
I have developed this rattle when accelerating hard in 4 th gear so will be doing this mod now
Thanks 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Are the cable ties just wedged in to compress the weights and stop them from moving ..or are they pulled tight through the cable tie eyelet like a normal cable tie? What size are the ties?
I didn’t use ties but superglue myself but you can go for both if you like. If you did use zip ties they have to be pretty large and long. Personally I’d stick with superglue and re do it in future if needed. TheThunder Rolls🇬🇧🇺🇸
Rus Member Since: 16 Jul 2019 Location: cape town Posts: 2 ![]() ![]() ![]() |
Thanks. Appreciate the detailed response.
Though slightly off topic, and having ran it for some time I’m really pleased with the Shift R V2 from TMD.
Makes for a really nice gear changes, would make for a really nice Christmas present for someone. Just thought I would put this out there, as it’s an ideal job to do whilst so living a gear stick rattle at the same time. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
^ do you have a link to that product please?
![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
