![]() | Home > Maintenance & Modifications > Puma Gearstick rattle / vibration cure guide (with photos) |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
Magoyo Member Since: 04 Feb 2022 Location: Buenos Aires Posts: 47 ![]() ![]() ![]() |
I did my job today, as you said, it was very easy to disassemble, but I found the weights very firm, without loose movements... I found some white grease, it is possible that more grease is needed, do you have any idea what kind of grease should be added? Thank you very much. and it is true, I had a little more work to place the cover but nothing impossible.
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 220 ![]() ![]() ![]() |
I did this repair over the weekend and have cured the rattle in 5th and 6th while on the Motorway, not tested it in low range yet. My son thought we had broken the gearbox due to the racket coming from the weights in low range.
I tried refitting the rubber gaiter with bicycle tyre levers but couldn't. I would recommend the carpet removal and pulling the rubber gaiter and then carpet over the gear lever before refitting this only needed 10 minutes in total as opposed to the 30 minutes wasted trying to pull the gaiter back up, not to mention the skin I've lost from my fingers. ![]() |
You can do it that way too yes, only some people with matting or carpet with sill protectors etc might find it even more work to take the matting out.
But yes. The ideal time to do it is with matting or carpet out. That also includes being the ideal time to fit a Shift R or Slickshift and grease up plus spacers fitting if anyone wanted to go that route. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Joe22 Member Since: 28 Apr 2023 Location: North West England Posts: 29 ![]() ![]() ![]() |
Can anyone advise if this would be the same ‘procedure’ in a 2004 110 td5?
Rattling in 5th / on the motorway is driving me insane ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
The TD5 has an entirely different gear lever, so unfortunately this procedure won't help you.
Perhaps some fixings are loose on the TD5? WeWillWin🇬🇧🇺🇸
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1110 ![]() ![]() ![]() |
Just joined the Rattling Gearstick Society and thanks to this thread fixed it in five minutes + the time to let the superglue cure
![]() I was also able to calm a friend down who told me yesterday there was something wrong with his gearbox - a rattle that goes away when he touches the gearstick. |
