Home > Maintenance & Modifications > Puma Gearstick rattle / vibration cure guide (with photos)
Page 5 of 6 <123456>
OldDD
Isle Of Man 2012 Defender 90 Puma 2.2 HT Orkney Grey
One other thing I would also check is the pointless plastic cover that covers the torx screw that hold the transfer lever in place. Mine was producing a rattle that was VERY similar to the dreaded clutch rattle so I used a bit of soft foam in the recess where the pedistal locates, reinstalled (now a very snug fit) and cured it.
Post #613508 31st Mar 2017 9:09am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Slickshift..
Reviving old thread - Slickshift now available for the Puma Defender:
https://secure.bellautoservices.co.uk/stor...ickshifts/
Post #639337 24th Jul 2017 7:39am
Naks
Err, Sadi, these have been available for a while now.
I ordered one from Synchro Gearboxes about 3 months ago, massive improvement with the gearshifts! --
Post #639340 24th Jul 2017 7:59am
DEF110DCPU
Belgium 2008 Defender 110 Puma 2.4 DCPU Stornoway Grey
thanks to this thread, rattle is stopped!
5 min work, no special tools needed
TOP!
Post #661375 2nd Nov 2017 10:00am
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up WeWillWin🇬🇧🇺🇸
Post #661394 2nd Nov 2017 12:28pm
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
Another happy Customer Thumbs Up
the super glueing also sorted my vibration problem so great news. If it helps, I used a pair of levers used to change a bicycle tyre to help replace the gearstick gaitor and it worked a treat. Sweatysock
110 CSW TDCI (Puma) 2007
Post #764241 18th Mar 2019 11:39pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Thanks here too. I just used my fingers to get the gaiter back on.
[Wanted - new fingers in good condition - please apply Joe the Plumber...!]
Post #765890 29th Mar 2019 7:16am
Huttopia
I’ve just joined this club. It was great to find a job at the right level for my technical ability. I even got the gaitor back on without breaking anything. Hurrah! Thanks for the clear instructions. Thumbs Up
Post #769134 18th Apr 2019 6:14pm
Post #769136 18th Apr 2019 7:09pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
I have developed this rattle when accelerating hard in 4 th gear so will be doing this mod now
Thanks 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #769165 19th Apr 2019 6:53am
nitram17
Are the cable ties just wedged in to compress the weights and stop them from moving ..or are they pulled tight through the cable tie eyelet like a normal cable tie? What size are the ties?
Post #769187 19th Apr 2019 11:49am
I didn’t use ties but superglue myself but you can go for both if you like. If you did use zip ties they have to be pretty large and long. Personally I’d stick with superglue and re do it in future if needed. WeWillWin🇬🇧🇺🇸
Post #769190 19th Apr 2019 12:09pm
Rus
South Africa 2008 Defender 90 Puma 2.4 SW Corris Grey
Thanks. Appreciate the detailed response.
Post #781673 16th Jul 2019 11:52am
Though slightly off topic, and having ran it for some time I’m really pleased with the Shift R V2 from TMD.
Makes for a really nice gear changes, would make for a really nice Christmas present for someone.
Just thought I would put this out there, as it’s an ideal job to do whilst so living a gear stick rattle at the same time. WeWillWin🇬🇧🇺🇸
Post #928538 4th Nov 2021 8:18pm
Naks
^ do you have a link to that product please? Thumbs Up --
Post #928584 5th Nov 2021 8:04am
